are the usb ports on rock64 on separate bus?
Are all the USB ports on the rock64 on separate bus. I dont have a rock64, else I could check using lsusb on linux.
I need to connect camera and a sensor on two different USB ports. If they are on the same bus it results to decreased or dropped frames from the camera.
If anyone operating linux on rock64 can give me the output of lsusb command, it would be helpful.
(09-21-2018, 10:57 PM)shome Wrote: Are all the USB ports on the rock64 on separate bus. I dont have a rock64, else I could check using lsusb on linux.
# lsusb  -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
   |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
   |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
       |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
       |__ Port 2: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
       |__ Port 2: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
       |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=cp210x, 12M
       |__ Port 4: Dev 6, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
  POE support for the Rock64 v3 h64poe 0 110 05-30-2021, 07:40 AM
Last Post: h64poe
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 1 180 05-21-2021, 05:44 PM
  Configuring Python GPIO Pin Control Rock64 www139 2 3,234 05-05-2021, 09:38 PM
Last Post: nolan
  How to enable ES9023-based DAC hat on Rock64? lowry 2 443 03-18-2021, 03:44 PM
Last Post: zborgerd
  1wire DS18b20 on Rock64? mypineme 3 1,495 02-10-2021, 11:21 AM
Last Post: TRS-80
  Display options for the Rock64 joey49 1 938 11-23-2020, 09:52 AM
Last Post: joey49
  Are HW design files available for ROCK64? irenek 1 1,276 09-29-2020, 05:57 PM
  No sound from Rock64 DAC codebreaker 2 1,241 09-29-2020, 02:14 PM
Last Post: codebreaker
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 1,110 08-21-2020, 09:16 PM
Last Post: prog-amateur
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 5,181 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
