External DAC - Pine64
Time to call for help.  (HELP!)
I'm trying to enable external DAC support on a distribution other than Volumio for the Pine64. (Not the Rock64 - for which there seems to be support.)  I have tried both Armbian Xenial desktop legacy kernel 3.10.y and 0.7.19-118 xenial minimal from ayufan.  The DAC is not recognized and it ports do not appear when one queries aplay.
Am missing something pretty basic like, duh, there is only a driver available for Volumio for the Pine64.
Why? I'm setting up multi room audio and was hoping to have a few "drone" devices with just snapcast and maybe some other stuff for home automation.  Wanted Ubuntu because I have more experience with it than others.  And I thought this would be easy.  (HA!)  At least I've learned a lot.
Thank you for your thoughts,
Matthew
When I set up spotifyd on my rockpro64 I had to manually enable the driver for usb audio, wasn't a massive deal though since I was compiling my own kernel anyways. I guess it might be similar for you, your external DAC might just need an option enabled in menuconfig.
Maybe the easiest way would be to just ask for the driver to be added to the ayufan kernel?
(09-04-2018, 12:08 PM)ah- Wrote: Maybe the easiest way would be to just ask for the driver to be added to the ayufan kernel?
Now that would be too easy now wouldn't it?  Cool
It may be in the kernel already and I just haven't muttered the proper incantation.  Klaatu Barata nickto . . .
The DAC is the Pine64 from the store here.  Just for reference.
Thanks,
Matthew
  Connecting external monitor to the Pinebook Fox7799 0 402 04-21-2019, 01:14 PM
Last Post: Fox7799
  Disable HDMI Pine64 Andruxa89 1 380 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 526 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 1,707 01-14-2019, 01:47 PM
Last Post: brigmohan
  Summer Undergraduate Research using Pine64's pkivolowitz 3 719 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 830 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 1,243 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 946 12-29-2016, 12:48 AM
Last Post: longsleep
  Finally got Emby server running on Pine64 clarkss12 3 1,729 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 1,114 09-04-2016, 09:25 PM
Last Post: S265
