undocumented leads on rockpro64
What are the leads marked PWR, GND, REC, GND for next to the headphone/mic port?
(09-01-2018, 05:54 PM)Firesped Wrote: What are the leads marked PWR, GND, REC, GND for next to the headphone/mic port?
the REC should be "RES" and sorry on the typo. "PWR" is Power On Switch and "REC" is Reset Switch.
The four pins is the mirror to the reset and power on switches and allows developers, especially casing that has its own power and reset buttons to derive out these two signals. Original plan to put a connector there but worry about block with PCIe card. you may ask where put the connector on this place that knowing may block PCIe card, the answer is layout engineer already runs out of idea on the suitable place.
  Installing Wifi drive for the RockPro64 John45595 0 177 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 675 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 628 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,096 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 837 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,243 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,705 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,524 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 963 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,703 10-21-2022, 07:44 AM
Last Post: rapier1
