Android Oreo 8.1 source code
Hi all,
after successful download and compile, I'm facing to the problem of writing an SD card with the Android 8 Image for my Rock64 board.
Is there a script to do the task?
Anybody knows where to get info about partitioning and writing image to the SD card?
I tried Etcher, but I have no output on the console.
Although, the stock image runs fine, so seems to me definitely a partitioning problems...
Any help?
(08-07-2018, 12:59 AM)shinymetal Wrote: Hi all,
Any help?
You may need the ROCKChip SD firmware tool, and I just attached on this post.
.zip   SD_Firmware_Tool._v1.46.zip (Size: 451.49 KB / Downloads: 313)
Hi Tllim,
thank you for your reply.
I've already installed ROCKChip SD firmware tool ( I forgot to mention ), what I don't know is what to do after the make command.
I think ./mkimage.sh, but I don't know what to use to flash.
I've tried mkupdate.sh ( obtaining the update.img file ), but ROCKChip SD firmware tool says me "opening firmware failed".
So, can you kindly tell me the steps to do after the compilation?
Or can you kindly address me where to find that informations?
Regards
(08-08-2018, 06:29 AM)shinymetal Wrote: Hi Shiny,
We are also facing same problem to get packaged .img for android 8 rock64 image.
If you had the procedure , can you pls share us.
Thanks & Regards,
Mahesh .
Hi
please help me to build the android 8.1
1- need source (link)
2- need tool-chain
3- ...
(09-01-2018, 04:30 AM)ma_f66 Wrote: Hi
2- need tool-chain
3- ...
http://files.pine64.org/os/sdk/ROCK64/RO...8.1.tar.gz
Thanks & Regards,
Mahesh .
Hello Mahesh,
Not yet,  I'm still trying
Any help?
ROCKChip SD firmware tool format sd update format not work,i want to know how to create a raw img for boot from sd card,could you give me some help thank you very much
not sure if im in the right area hopefully someone can direct me, i would like to add an audio api to the version of android for the rock64 and just need a little guidance, i tried seeking assistance on xda but have not got an answer
Anyone that can upload a zip of the device/rockchip folder?
I modified something and need the originals files.
I can't download a whole 60GB tar zip again I deleted.
Why doesn't Pine upload everything to Github, it would make everything easier.
(02-09-2019, 01:21 PM)Blinky Wrote: Anyone that can upload a zip of the device/rockchip folder?
https://transfer.sh/AuR6N/rockchip.zip
There you go
Did you manage to successfully boot android oreo from the sources provided by pine?
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,246 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,016 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,541 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,292 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,012 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,497 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,999 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,574 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,719 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,767 09-09-2020, 08:44 AM
Last Post: BowerR64
