Best configuration for Samsung NVMe
I bought a Samsung nvme 970 EVO for the PCIe slot. I tried to find how to format the nvme unit but I have no clear. Could you help me in formatting and configuration? (currently I have put with bionic-containers, with Lxde the system does not work properly)
Did you get sorted?
If notyou probably want to follow Bullet64 instructions on the second page of this thread.
Which sorts the partitioning (none) and formatting (same as your current boot disk) and sets it up as the root partition.[url=https://forum.pine64.org/showthread.php?tid=6082][/url]
(08-06-2018, 01:32 PM)dukla2000 Wrote: Did you get sorted?
Ok, thank you very much for your help
  Booting from NVME ilovegentoo 11 17,663 05-10-2021, 02:06 PM
Last Post: rrowles2000
  Is PCIE x4 bootable for NVMe SSD under Linux jzhang18 48 73,290 12-25-2018, 03:05 PM
Last Post: Atch
  Disable sdio (no wifi/bt) to fix pcie/nvme support RockPro64Newbie 0 2,479 09-22-2018, 04:07 PM
Last Post: RockPro64Newbie
Information PCIe -> SATA and NVMe work as of 0.6.59 Luke 13 21,210 08-06-2018, 11:33 AM
Last Post: dukla2000
