07-17-2016, 03:42 AM
Congratulations to the engineer. Tell him to enjoy this wonderful time.
HW Acceleration Working
07-17-2016, 07:41 AM
(07-16-2016, 07:35 PM)tllim Wrote:(07-14-2016, 06:59 PM)nagmier Wrote:The Allwinner engineer who involved in 64-bit MALI porting just becomes father and takes few days off. He will back in office on July 18, and I will follow up with him again.(07-02-2016, 09:50 PM)tllim Wrote: Back in Mali topic, Allwinner already make the first release and I aware that still not usable. If somebody able to provide me a clear issues and requests, I will translate and provide back to engineer. Congrats to him on the child, days off are well deserved. TLLIM based on your reply I'm guessing that people have in fact been relaying the technical information needed to you so that you can then forward it to AW? As there were no responses inside the thread it looks like you were ignored.
07-19-2016, 06:09 PM
(This post was last modified: 07-19-2016, 06:10 PM by lenny.raposo-pine64.pro.)
Ok folks first compile DMESG (integration with longsleep kernel work)
looking good somewhat [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.102-mali (administrator@laptop) (gcc version 4.9.2 ( 4.9.2-10) ) #4 SMP PREEMPT Tue Jul 19 15:34:05 EDT 2016 [ 0.000000] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] Machine: sun50iw1p1 [ 0.000000] cma: CMA: reserved 64 MiB at 7c000000 [ 0.000000] On node 0 totalpages: 258048 [ 0.000000] DMA zone: 3528 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 258048 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script buffer is NULL! [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv0.2 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc03af98000 s19136 r8192 d21824 u49152 [ 0.000000] pcpu-alloc: s19136 r8192 d21824 u49152 alloc=12*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 254520 [ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr=36:c9:e3:f1:b8:05 root=/dev/mmcblk0p2 ro rootwait [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000000] Memory: 1008MB = 1008MB total [ 0.000000] Memory: 936544k/936544k available, 95648k reserved [ 0.000000] Virtual kernel memory layout: vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB) vmemmap : 0xffffffbc00e38000 - 0xffffffbc01c00000 ( 13 MB) modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) memory : 0xffffffc000000000 - 0xffffffc03f000000 ( 1008 MB) .init : 0xffffffc0009fc000 - 0xffffffc000a80ac0 ( 531 kB) .text : 0xffffffc000080000 - 0xffffffc0009fba64 ( 9711 kB) .data : 0xffffffc000a81000 - 0xffffffc000bdc500 ( 1390 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Console: colour dummy device 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 7.011377] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 7.011408] pid_max: default: 32768 minimum: 301 [ 7.011512] Security Framework initialized [ 7.011566] AppArmor: AppArmor initialized [ 7.011611] Mount-cache hash table entries: 256 [ 7.022328] Initializing cgroup subsys memory [ 7.022389] Initializing cgroup subsys devices [ 7.022406] Initializing cgroup subsys freezer [ 7.022422] Initializing cgroup subsys blkio [ 7.022437] Initializing cgroup subsys perf_event [ 7.022459] Initializing cgroup subsys hugetlb [ 7.022528] ftrace: allocating 27430 entries in 108 pages [ 7.055547] CPU0: update cpu_power 1968128 [ 7.055579] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 7.056519] virtual base = 0xffffff800000a000. [ 7.056538] gicd_base = 0xffffff800000c000. [ 7.056551] gicc_base = 0xffffff800000e000. [ 7.057120] CPU1: Booted secondary processor [ 7.057145] CPU1: update cpu_power 1968128 [ 7.059744] CPU2: Booted secondary processor [ 7.059757] CPU2: update cpu_power 1968128 [ 7.063862] CPU3: Booted secondary processor [ 7.063874] CPU3: update cpu_power 1968128 [ 7.063957] Brought up 4 CPUs [ 7.064031] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 7.064634] devtmpfs: initialized [ 7.069454] atomic64 test passed [ 7.069471] pinctrl core: initialized pinctrl subsystem [ 7.071998] NET: Registered protocol family 16 [ 7.072249] script_sysfs_init success [ 7.072466] dump_class_init,806, success [ 7.072735] vdso: 2 pages (1 code, 1 data) at base ffffffc000a89000 [ 7.072766] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 7.074025] software IO TLB [mem 0x79c00000-0x7a000000] (4MB) mapped at [ffffffc038c00000-ffffffc038ffffff] [ 7.075078] DMA: preallocated 256 KiB pool for atomic allocations [ 7.075226] Serial: AMBA PL011 UART driver [ 7.075336] axp81x_board_init: axp regl_devs num = 23 [ 7.075478] pll_audio-set_default_rate=24576000 success! [ 7.075508] pll_video0-set_default_rate=297000000 success! [ 7.075591] pll_video1-set_default_rate=297000000 success! [ 7.075660] pll_de-set_default_rate=297000000 success! [ 7.076423] de-set_default_source=pll_de success! [ 7.076439] de-set_default_rate=297000000 success! [ 7.076496] tcon0-set_default_source=pll_mipi success! [ 7.076543] tcon1-set_default_source=pll_video0 success! [ 7.076785] hdmi-set_default_source=pll_video0 success! [ 7.079013] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 7.079193] [sun50iw1p1_pinctrl_probe][838] [ 7.080855] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 7.081516] sunxi hwspinlock vbase:0xffffff800005c000 [ 7.087250] sunxi_chipid_probe,150: soc bin:0 [ 7.092166] bio: create slab <bio-0> at 0 [ 7.092522] pwm module init! [ 7.093743] SCSI subsystem initialized [ 7.093879] usbcore: registered new interface driver usbfs [ 7.093925] usbcore: registered new interface driver hub [ 7.093999] usbcore: registered new device driver usb [ 7.094780] Linux video capture interface: v2.00 [ 7.095241] [ARISC] unxi-arisc driver v1.10 [ 7.102001] [ARISC] unxi-arisc driver v1.10 startup succeeded [ 7.102245] Advanced Linux Sound Architecture Driver Initialized. [ 7.102607] NetLabel: Initializing [ 7.102620] NetLabel: domain hash size = 128 [ 7.102632] NetLabel: protocols = UNLABELED CIPSOv4 [ 7.102679] NetLabel: unlabeled traffic allowed by default [ 7.102846] [pm]aw_pm_init! [ 7.102909] rtc physical base = 0x0000000001f00000 . [ 7.102950] np name = /soc@01c00000/rtc@01f00000. [ 7.102966] base = ffffff8000070100, len = 4. [ 7.102979] pmu name: pmu0 . [ 7.103016] pmu0_enable = 0x1. [ 7.103028] pmux_id = 0x6. [ 7.103040] pmux_twi_id = 0x1. [ 7.103052] pmux_twi_addr = 0x34. [ 7.103063] pmu name: pmu1 . [ 7.103112] Warning: can not find np for pmu1. [ 7.103336] add_sys_pwr_dm: get ldo name for id: vcc-lpddr failed [ 7.103501] after inited: sys_mask config = 0x4a55. [ 7.103533] Warning: can not find np for dynamic_standby_para. [ 7.103653] [pm]valid [ 7.103663] [pm]valid [ 7.103672] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby. [ 7.103883] Switching to clocksource arch_sys_counter [ 7.114452] AppArmor: AppArmor Filesystem Enabled [ 7.121304] NET: Registered protocol family 2 [ 7.122037] TCP established hash table entries: 8192 (order: 5, 131072 bytes) [ 7.122199] TCP bind hash table entries: 8192 (order: 5, 131072 bytes) [ 7.122361] TCP: Hash tables configured (established 8192 bind 8192) [ 7.122442] TCP: reno registered [ 7.122459] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 7.122498] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 7.122711] NET: Registered protocol family 1 [ 7.122989] RPC: Registered named UNIX socket transport module. [ 7.123006] RPC: Registered udp transport module. [ 7.123019] RPC: Registered tcp transport module. [ 7.123033] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 7.123201] Trying to unpack rootfs image as initramfs... [ 7.169159] Freeing initrd memory: 1072K (ffffffc035dab000 - ffffffc035eb7000) [ 7.169698] kvm [1]: Using HYP init bounce page @79b85000 [ 7.170157] kvm [1]: interrupt-controller@1c84000 IRQ25 [ 7.170569] kvm [1]: timer IRQ27 [ 7.170592] kvm [1]: Hyp mode initialized successfully [ 7.172401] lock super standby defaultly! [ 7.172423] lookup_scene_lock_name: new scene lock super_standby [ 7.172439] scene_lock_init name=super_standby [ 7.172454] scene_lock: super_standby, type 5, count 1 [ 7.172883] audit: initializing netlink socket (disabled) [ 7.172944] type=2000 audit(0.150:1): initialized [ 7.173550] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 7.174034] VFS: Disk quotas dquot_6.5.2 [ 7.174152] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 7.174567] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 7.175096] NFS: Registering the id_resolver key type [ 7.175151] Key type id_resolver registered [ 7.175164] Key type id_legacy registered [ 7.175184] Installing knfsd (copyright © 1996 okir@monad.swb.de). [ 7.175338] NTFS driver 2.1.30 [Flags: R/W]. [ 7.175507] fuse init (API version 7.22) [ 7.175707] msgmni has been set to 1959 [ 7.176661] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 7.176766] io scheduler noop registered [ 7.176781] io scheduler deadline registered [ 7.176815] io scheduler cfq registered (default) [ 7.177343] [DISP]disp_module_init [ 7.177646] disp 1000000.disp: unable to map dsi registers [ 7.177683] disp: probe of 1000000.disp failed with error -22 [ 7.177841] [DISP]disp_module_init finish [ 7.178146] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 7.178178] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n [ 8.104251] console [ttyS0] enabled [ 8.108520] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI [ 8.115330] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI [ 8.122232] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI [ 8.129118] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI [ 8.136017] misc dump reg init [ 8.139501] [drm] Initialized drm 1.1.0 20060810 [ 8.149004] brd: module loaded [ 8.154697] loop: module loaded [ 8.158395] sunxi-bt bt.27: Missing bt_power. [ 8.163164] sunxi-bt bt.27: bt_power_name ((null)) [ 8.168417] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io) [ 8.174541] sunxi-bt bt.27: bt_rst gpio=356 mul-sel=1 pull=-1 drv_level=-1 data=0 [ 8.183154] sunxi-bt bt.27: clk not config [ 8.187716] sunxi-bt bt.27: block state already is 1 [ 8.193331] sunxi-wlan wlan.26: wlan_busnum (1) [ 8.198299] sunxi-wlan wlan.26: Missing wlan_power. [ 8.203636] sunxi-wlan wlan.26: wlan_power_name ((null)) [ 8.209457] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io) [ 8.215956] sunxi-wlan wlan.26: wlan_regon gpio=354 mul-sel=1 pull=-1 drv_level=-1 data=0 [ 8.225302] sunxi-wlan wlan.26: wlan_hostwake gpio=355 mul-sel=6 pull=-1 drv_level=-1 data=0 [ 8.234939] sunxi-wlan wlan.26: clk not config [ 8.240383] tun: Universal TUN/TAP device driver, 1.6 [ 8.245920] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 8.253274] WARNING: Get ephy clock is failed [ 8.258366] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 8.265635] get ehci0-controller drv_vbus_gpio is fail [ 8.271256] get ehci0-controller, regulator_io is no nocare [ 8.277409] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c87e50, 0x:ffffff80000aa000, irq_no:68 [ 8.290692] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 8.300618] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1 [ 8.310443] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000504ef0 [ 8.333950] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00 [ 8.341962] hub 1-0:1.0: USB hub found [ 8.346085] hub 1-0:1.0: 1 port detected [ 8.350504] scene_lock_init name=ehci_standby [ 8.355357] get ehci1-controller drv_vbus_gpio is fail [ 8.360978] get ehci1-controller, regulator_io is no nocare [ 8.367121] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000c880a0, 0x:ffffff80000b2000, irq_no:6a [ 8.380400] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 8.390326] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2 [ 8.400011] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000504ef0 [ 8.422508] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00 [ 8.430426] hub 2-0:1.0: USB hub found [ 8.434550] hub 2-0:1.0: 1 port detected [ 8.438956] scene_lock_init name=ehci_standby [ 8.443981] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 8.450874] get ohci0-controller drv_vbus_gpio is fail [ 8.456508] get ohci0-controller, regulator_io is no nocare [ 8.462645] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c879b0 [ 8.472881] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 8.482422] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3 [ 8.491879] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc000508690 [ 8.554686] hub 3-0:1.0: USB hub found [ 8.558794] hub 3-0:1.0: 1 port detected [ 8.563217] scene_lock_init name=ohci_standby [ 8.568032] get ohci1-controller drv_vbus_gpio is fail [ 8.573668] get ohci1-controller, regulator_io is no nocare [ 8.579792] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000c87c00 [ 8.590025] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 8.599556] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4 [ 8.609011] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0xffffffc000508690 [ 8.672722] hub 4-0:1.0: USB hub found [ 8.676831] hub 4-0:1.0: 1 port detected [ 8.681245] scene_lock_init name=ohci_standby [ 8.686278] usbcore: registered new interface driver usb-storage [ 8.692892] usbcore: registered new interface driver ums-alauda [ 8.699406] usbcore: registered new interface driver ums-cypress [ 8.705999] usbcore: registered new interface driver ums-datafab [ 8.712601] usbcore: registered new interface driver ums_eneub6250 [ 8.719394] usbcore: registered new interface driver ums-freecom [ 8.725985] usbcore: registered new interface driver ums-isd200 [ 8.732494] usbcore: registered new interface driver ums-jumpshot [ 8.739190] usbcore: registered new interface driver ums-karma [ 8.745591] usbcore: registered new interface driver ums-onetouch [ 8.752294] usbcore: registered new interface driver ums-realtek [ 8.758897] usbcore: registered new interface driver ums-sddr09 [ 8.765394] usbcore: registered new interface driver ums-sddr55 [ 8.771900] usbcore: registered new interface driver ums-usbat [ 8.778425] usbcore: registered new interface driver usbserial [ 8.784828] usbcore: registered new interface driver usbserial_generic [ 8.791997] usbserial: USB Serial support registered for generic [ 8.798781] mousedev: PS/2 mouse device common for all mice [ 8.805276] input: sunxi-keyboard as /devices/virtual/input/input0 [ 8.812539] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0 [ 8.820003] sunxi-rtc 1f00000.rtc: RTC enabled [ 8.825048] i2c /dev entries driver [ 8.865856] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1 [ 8.879356] sunxi budget cooling probe start ! [ 8.884243] CPU freq cooling register Success [ 8.889048] CPU hotplug cooling register Success [ 8.894173] CPU budget cooling register Success [ 8.899354] sunxi gpu cooling probe start ! [ 8.903932] CPU gpu cooling register Success [ 8.911373] cpuidle: using governor ladder [ 8.915865] cpuidle: using governor menu [ 8.920837] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 15:30:22 [ 8.933710] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none [ 8.940383] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none [ 8.947150] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc [ 8.954245] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found [ 8.960432] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found [ 8.967108] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166. [ 8.972825] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.983789] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator [ 9.003081] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.032599] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000d8000 irq:92 [ 9.039821] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 15:30:22 [ 9.052686] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string [ 9.059634] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string [ 9.066686] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string [ 9.073736] get() with no identifier [ 9.077640] get() with no identifier [ 9.081543] get() with no identifier [ 9.085456] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found [ 9.091650] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found [ 9.097931] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found [ 9.104555] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.115516] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator [ 9.131793] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !! [ 9.139267] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !! [ 9.140824] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.157355] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.160522] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000e0000 irq:93 [ 9.161065] usbcore: registered new interface driver usbhid [ 9.161066] usbhid: USB HID core driver [ 9.186411] usbcore: registered new interface driver snd-usb-audio [ 9.188333] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.190460] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.191271] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.192080] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.192890] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.193517] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 9.193557] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 9.195927] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 9.216736] mmc0: host does not support reading read-only switch. assuming write-enable. [ 9.218588] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B [ 9.218628] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B [ 9.218726] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B [ 9.218746] mmc0: new high speed SDHC card at address 59b4 [ 9.314271] mmcblk0: mmc0:59b4 NCard 7.48 GiB [ 9.319925] sndhdmi sound.7: sndhdmi <-> 1c22800.daudio mapping ok [ 9.320145] mmcblk0: p1 p2 [ 9.330720] TCP: cubic registered [ 9.331016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 9.331829] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 9.331847] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.334246] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.336061] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !! [ 9.336867] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.337672] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.338478] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.339280] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.340085] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.340889] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.341693] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.342498] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.342511] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.343341] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !! [ 9.343354] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 9.458901] NET: Registered protocol family 10 [ 9.464410] sit: IPv6 over IPv4 tunneling driver [ 9.469816] NET: Registered protocol family 17 [ 9.474721] 8021q: 802.1Q VLAN Support v1.8 [ 9.479340] Key type dns_resolver registered [ 9.484184] Registering SWP/SWPB emulation handler [ 9.489684] registered taskstats version 1 [ 9.495041] Key type encrypted registered [ 9.499440] AppArmor: AppArmor sha1 policy hashing enabled [ 9.505759] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail [ 9.514327] [DISP] boot_disp:0x0 [ 9.518525] [HDMI] power vcc-hdmi-33 [ 9.522890] [HDMI] cec support = 0 [ 9.633809] sunxi-rtc 1f00000.rtc: setting system clock to 2016-07-19 20:49:53 UTC (1468961393) [ 9.643895] input: sunxi-ths as /devices/virtual/input/input2 [ 9.650310] thermal thermal_zone0: failed to read out thermal zone 0 [ 9.657648] ALSA device list: [ 9.660889] #0: sndhdmi [ 9.664159] Freeing unused kernel memory: 528K (ffffffc0009fc000 - ffffffc000a80000) [ 9.731332] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities [ 9.740736] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities [ 9.880788] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 10.143556] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 10.158365] systemd[1]: Detected architecture 'arm64'. [ 10.204768] systemd[1]: Set hostname to <pine64>. [ 10.507950] systemd[1]: Expecting device dev-ttyS0.device... [ 10.528341] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 10.536860] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 10.545213] systemd[1]: Starting Remote File Systems (Pre). [ 10.567668] systemd[1]: Reached target Remote File Systems (Pre). [ 10.574393] systemd[1]: Starting Encrypted Volumes. [ 10.597186] systemd[1]: Reached target Encrypted Volumes. [ 10.603143] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 10.612023] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 10.620733] systemd[1]: Starting Paths. [ 10.636540] systemd[1]: Reached target Paths. [ 10.641377] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 10.651710] systemd[1]: Starting Swap. [ 10.675905] systemd[1]: Reached target Swap. [ 10.680604] systemd[1]: Expecting device dev-mmcblk0p1.device... [ 10.705432] systemd[1]: Starting Root Slice. [ 10.725106] systemd[1]: Created slice Root Slice. [ 10.730277] systemd[1]: Starting User and Session Slice. [ 10.754627] systemd[1]: Created slice User and Session Slice. [ 10.760941] systemd[1]: Starting Delayed Shutdown Socket. [ 10.784150] systemd[1]: Listening on Delayed Shutdown Socket. [ 10.790465] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 10.813669] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 10.821315] systemd[1]: Starting Journal Socket (/dev/log). [ 10.843190] systemd[1]: Listening on Journal Socket (/dev/log). [ 10.849712] systemd[1]: Starting udev Control Socket. [ 10.872723] systemd[1]: Listening on udev Control Socket. [ 10.878670] systemd[1]: Starting udev Kernel Socket. [ 10.902229] systemd[1]: Listening on udev Kernel Socket. [ 10.908097] systemd[1]: Starting Journal Socket. [ 10.931750] systemd[1]: Listening on Journal Socket. [ 10.937292] systemd[1]: Starting System Slice. [ 10.961269] systemd[1]: Created slice System Slice. [ 10.966669] systemd[1]: Started File System Check on Root Device. [ 10.973370] systemd[1]: Starting system-systemd\x2dfsck.slice. [ 11.000670] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 11.007568] systemd[1]: Starting system-getty.slice. [ 11.030153] systemd[1]: Created slice system-getty.slice. [ 11.036087] systemd[1]: Starting system-serial\x2dgetty.slice. [ 11.059661] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 11.066604] systemd[1]: Starting Increase datagram queue length... [ 11.069477] [ehci0-controller]: sunxi_usb_disable_ehci [ 11.069483] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c87e50 [ 11.069497] scene_lock_destroy name=ehci_standby [ 11.069506] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4 [ 11.069521] usb usb1: USB disconnect, device number 1 [ 11.069967] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered [ 11.069995] [ohci0-controller]: sunxi_usb_disable_ohci [ 11.069999] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c879b0 [ 11.070001] scene_lock_destroy name=ohci_standby [ 11.070007] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4 [ 11.070019] usb usb3: USB disconnect, device number 1 [ 11.070318] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered [ 11.070341] [ehci0-controller]: sunxi_usb_enable_ehci [ 11.070346] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c87e50, 0x:ffffff80000aa000, irq_no:68 [ 11.070382] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 11.070397] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1 [ 11.192282] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc039987dc0 [ 11.217067] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00 [ 11.218714] systemd[1]: Starting Restore / save the current clock... [ 11.232172] hub 1-0:1.0: USB hub found [ 11.236784] hub 1-0:1.0: 1 port detected [ 11.243906] scene_lock_init name=ehci_standby [ 11.249735] [ohci0-controller]: sunxi_usb_enable_ohci [ 11.255259] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c879b0 [ 11.265488] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 11.269257] systemd[1]: Mounting Huge Pages File System... [ 11.281101] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3 [ 11.281141] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc00045eb40 [ 11.318978] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 11.339587] hub 3-0:1.0: USB hub found [ 11.343714] hub 3-0:1.0: 1 port detected [ 11.348321] scene_lock_init name=ohci_standby [ 11.367203] systemd[1]: Started Set Up Additional Binary Formats. [ 11.386802] systemd[1]: Starting Load Kernel Modules... [ 11.415441] systemd[1]: Mounting POSIX Message Queue File System... [ 11.444954] systemd[1]: Starting udev Coldplug all Devices... [ 11.474749] systemd[1]: Mounting Debug File System... [ 11.504195] systemd[1]: Starting Slices. [ 11.522241] systemd[1]: Reached target Slices. [ 11.541954] systemd[1]: Mounted Debug File System. [ 11.571494] systemd[1]: Mounted POSIX Message Queue File System. [ 11.600972] systemd[1]: Mounted Huge Pages File System. [ 11.630472] systemd[1]: Started Increase datagram queue length. [ 11.660015] systemd[1]: Started Restore / save the current clock. [ 11.689534] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 11.703574] systemd[1]: Time has been changed [ 11.742055] systemd[1]: Starting Create Static Device Nodes in /dev... [ 11.770786] systemd[1]: Starting Syslog Socket. [ 11.788138] systemd[1]: Listening on Syslog Socket. [ 11.793709] systemd[1]: Starting Journal Service... [ 11.837162] systemd[1]: Started Journal Service. [ 11.934208] cfg80211: Calling CRDA to update world regulatory domain [ 12.106509] RTL871X: module init start [ 12.110302] systemd-udevd[171]: starting version 215 [ 12.116194] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844 [ 12.123639] RTL871X: build time: Jul 19 2016 15:52:07 [ 12.129160] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844 [ 12.137486] sunxi-wlan wlan.26: bus_index: 1 [ 12.142368] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000 [ 12.260843] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 12.260914] RTL871X: module init ret=0 [ 12.277430] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator [ 12.299516] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 12.329818] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 12.337304] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 12.343986] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 12.359926] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 12.373644] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !! [ 12.380635] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 12.401640] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B [ 12.416364] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B [ 12.428848] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B [ 12.443554] mmc1: new high speed SDIO card at address 0001 [ 12.496087] RTL871X: rtw_ndev_init(wlan0) [ 12.501681] RTL871X: rtw_ndev_init(wlan1) [ 12.692580] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 12.915906] sunxi cedar version 0.1 [ 12.920566] [cedar]: install start!!! [ 12.924729] ycy the get irq is 90 [ 12.931649] ycy clk_bass_vir 0x18 is ffffff80017ee018, the value:3006207 [ 12.940068] ycy clk_bass_vir 0x13c is ffffff80017ee13c, the value:0 [ 12.947780] ycy clk_bass_vir 0x64 is ffffff80017ee064, the value:601810 [ 12.955531] ycy clk_bass_vir 0x2c4 is ffffff80017ee2c4, the value:601c10 [ 12.963901] ycy clk_bass_vir 0x100 is ffffff80017ee100, the value:0 [ 12.971905] [cedar]: install end!!! [ 13.130119] Registered IR keymap rc_map_sunxi [ 13.135387] input: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0/input3 [ 13.143549] rc0: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0 [ 13.306149] IR RC6 protocol handler initialized [ 13.306152] IR RC5(x) protocol handler initialized [ 13.327113] IR SANYO protocol handler initialized [ 13.327115] IR JVC protocol handler initialized [ 13.337537] IR Sony protocol handler initialized [ 13.361686] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input4 [ 13.361919] lirc_dev: IR Remote Control driver registered, major 249 [ 13.378255] IR MCE Keyboard/mouse protocol handler initialized [ 13.378415] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0 [ 13.378417] IR LIRC bridge handler initialized [ 13.445016] IR NEC protocol handler initialized [ 13.484084] sunxi-bt bt.27: set block: 0 [ 13.488524] sunxi-bt bt.27: check bluetooth io_regulator voltage: 1800000 [ 13.518982] [VFE]cci probe end cci_sel = 0! [ 13.523913] [VFE]cci_init end [ 13.819988] cfg80211: World regulatory domain updated: [ 13.825653] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 13.834643] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 13.842737] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 13.850850] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 13.858956] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.867055] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.875703] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 13.886204] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.897155] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 14.048796] [VFE]Welcome to Video Front End driver [ 14.054663] [VFE]csi probe end csi_sel = 0! [ 14.059656] [VFE]csi_init end [ 14.063667] [VFE]isp probe start isp_sel = 0! [ 14.069807] [ISP] isp platform_id = 3! [ 14.074188] [VFE]isp probe end isp_sel = 0! [ 14.079389] [VFE]sunxi_isp_platform_register end [ 14.085381] [VFE]mipi probe start mipi_sel = 0! [ 14.090791] [VFE]mipi probe end mipi_sel = 0! [ 14.095613] [VFE]mipi_init end [ 14.100227] [VFE]flash_init end [ 14.104516] [VFE]pdev->id = 0 [ 14.107763] [VFE]dev->vip_sel = 0 [ 14.111821] [VFE]vfe_init end [ 14.119896] [VFE]probe_work_handle start! [ 14.124846] [VFE]vfe_runtime_resume [ 14.143127] [VFE]..........................vfe clk open!....................... [ 14.151149] [VFE_WARN]vfe dphy clock is null [ 14.155866] [VFE]V4L2 device registered as (null) [ 14.161072] [VFE]vfe_runtime_suspend [ 14.164987] [VFE]..........................vfe clk close!....................... [ 14.181872] [VFE]probe_work_handle end! [ 14.368233] sunxidrm: exports duplicate symbol dsi_dcs_rd (owned by kernel) [ 14.589990] systemd-journald[168]: Received request to flush runtime journal from PID 1 [ 20.985007] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 26.165822] libphy: 1c30000.eth: probed [ 26.170189] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00) [ 30.099986] libphy: 1c30000.eth-0:00 - Link is Up - 100/Full [ 32.399428] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 33.397930] libphy: 1c30000.eth: probed [ 33.402296] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00) [ 33.457593] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 34.360480] libphy: 1c30000.eth: probed [ 34.364814] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00) [ 34.421379] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 38.296537] libphy: 1c30000.eth-0:00 - Link is Up - 100/Full [ 38.302831] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready A little bit more rework and it falls apart time to undo changes [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.102-mali-2 (administrator@laptop) (gcc version 4.9.2 ( 4.9.2-10) ) #5 SMP PREEMPT Tue Jul 19 18:48:24 EDT 2016 [ 0.000000] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] Machine: sun50iw1p1 [ 0.000000] cma: CMA: reserved 64 MiB at 7c000000 [ 0.000000] On node 0 totalpages: 258048 [ 0.000000] DMA zone: 3528 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 258048 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script buffer is NULL! [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv0.2 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc03af98000 s19136 r8192 d21824 u49152 [ 0.000000] pcpu-alloc: s19136 r8192 d21824 u49152 alloc=12*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 254520 [ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr=36:c9:e3:f1:b8:05 root=/dev/mmcblk0p2 ro rootwait [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000000] Memory: 1008MB = 1008MB total [ 0.000000] Memory: 937596k/937596k available, 94596k reserved [ 0.000000] Virtual kernel memory layout: vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB) vmemmap : 0xffffffbc00e38000 - 0xffffffbc01c00000 ( 13 MB) modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) memory : 0xffffffc000000000 - 0xffffffc03f000000 ( 1008 MB) .init : 0xffffffc0009b7000 - 0xffffffc000a39ac0 ( 523 kB) .text : 0xffffffc000080000 - 0xffffffc0009b69e4 ( 9435 kB) .data : 0xffffffc000a3a000 - 0xffffffc000adb900 ( 647 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Console: colour dummy device 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 6.956940] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 6.956971] pid_max: default: 32768 minimum: 301 [ 6.957074] Security Framework initialized [ 6.957127] AppArmor: AppArmor initialized [ 6.957172] Mount-cache hash table entries: 256 [ 6.967725] Initializing cgroup subsys memory [ 6.967784] Initializing cgroup subsys devices [ 6.967802] Initializing cgroup subsys freezer [ 6.967818] Initializing cgroup subsys blkio [ 6.967833] Initializing cgroup subsys perf_event [ 6.967854] Initializing cgroup subsys hugetlb [ 6.967924] ftrace: allocating 26490 entries in 104 pages [ 6.999789] CPU0: update cpu_power 1968128 [ 6.999822] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 7.000765] virtual base = 0xffffff800000a000. [ 7.000784] gicd_base = 0xffffff800000c000. [ 7.000797] gicc_base = 0xffffff800000e000. [ 7.001353] CPU1: Booted secondary processor [ 7.001377] CPU1: update cpu_power 1968128 [ 7.003978] CPU2: Booted secondary processor [ 7.003990] CPU2: update cpu_power 1968128 [ 7.008097] CPU3: Booted secondary processor [ 7.008108] CPU3: update cpu_power 1968128 [ 7.008187] Brought up 4 CPUs [ 7.008261] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 7.008857] devtmpfs: initialized [ 7.013608] atomic64 test passed [ 7.013627] pinctrl core: initialized pinctrl subsystem [ 7.016143] NET: Registered protocol family 16 [ 7.016399] script_sysfs_init success [ 7.016615] dump_class_init,806, success [ 7.016881] vdso: 2 pages (1 code, 1 data) at base ffffffc000a41000 [ 7.016913] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 7.018172] software IO TLB [mem 0x79c00000-0x7a000000] (4MB) mapped at [ffffffc038c00000-ffffffc038ffffff] [ 7.019224] DMA: preallocated 256 KiB pool for atomic allocations [ 7.019374] Serial: AMBA PL011 UART driver [ 7.019483] axp81x_board_init: axp regl_devs num = 23 [ 7.019624] pll_audio-set_default_rate=24576000 success! [ 7.019653] pll_video0-set_default_rate=297000000 success! [ 7.019735] pll_video1-set_default_rate=297000000 success! [ 7.019801] pll_de-set_default_rate=297000000 success! [ 7.020549] de-set_default_source=pll_de success! [ 7.020565] de-set_default_rate=297000000 success! [ 7.020619] tcon0-set_default_source=pll_mipi success! [ 7.020665] tcon1-set_default_source=pll_video0 success! [ 7.020904] hdmi-set_default_source=pll_video0 success! [ 7.023143] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 7.023322] [sun50iw1p1_pinctrl_probe][838] [ 7.024984] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 7.025636] sunxi hwspinlock vbase:0xffffff800005c000 [ 7.031306] sunxi_chipid_probe,150: soc bin:0 [ 7.036163] bio: create slab <bio-0> at 0 [ 7.036519] pwm module init! [ 7.037726] SCSI subsystem initialized [ 7.037860] usbcore: registered new interface driver usbfs [ 7.037905] usbcore: registered new interface driver hub [ 7.037979] usbcore: registered new device driver usb [ 7.038746] Linux video capture interface: v2.00 [ 7.039199] [ARISC] unxi-arisc driver v1.10 [ 7.045925] [ARISC] unxi-arisc driver v1.10 startup succeeded [ 7.046167] Advanced Linux Sound Architecture Driver Initialized. [ 7.046522] NetLabel: Initializing [ 7.046536] NetLabel: domain hash size = 128 [ 7.046548] NetLabel: protocols = UNLABELED CIPSOv4 [ 7.046596] NetLabel: unlabeled traffic allowed by default [ 7.046762] [pm]aw_pm_init! [ 7.046825] rtc physical base = 0x0000000001f00000 . [ 7.046867] np name = /soc@01c00000/rtc@01f00000. [ 7.046883] base = ffffff8000070100, len = 4. [ 7.046896] pmu name: pmu0 . [ 7.046933] pmu0_enable = 0x1. [ 7.046945] pmux_id = 0x6. [ 7.046957] pmux_twi_id = 0x1. [ 7.046969] pmux_twi_addr = 0x34. [ 7.046980] pmu name: pmu1 . [ 7.047031] Warning: can not find np for pmu1. [ 7.047254] add_sys_pwr_dm: get ldo name for id: vcc-lpddr failed [ 7.047418] after inited: sys_mask config = 0x4a55. [ 7.047448] Warning: can not find np for dynamic_standby_para. [ 7.047581] [pm]valid [ 7.047591] [pm]valid [ 7.047600] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby. [ 7.047812] Switching to clocksource arch_sys_counter [ 7.058377] AppArmor: AppArmor Filesystem Enabled [ 7.065177] NET: Registered protocol family 2 [ 7.065910] TCP established hash table entries: 8192 (order: 5, 131072 bytes) [ 7.066068] TCP bind hash table entries: 8192 (order: 5, 131072 bytes) [ 7.066243] TCP: Hash tables configured (established 8192 bind 8192) [ 7.066326] TCP: reno registered [ 7.066342] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 7.066381] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 7.066593] NET: Registered protocol family 1 [ 7.066880] RPC: Registered named UNIX socket transport module. [ 7.066898] RPC: Registered udp transport module. [ 7.066911] RPC: Registered tcp transport module. [ 7.066924] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 7.067092] Trying to unpack rootfs image as initramfs... [ 7.113057] Freeing initrd memory: 1072K (ffffffc035dab000 - ffffffc035eb7000) [ 7.113594] kvm [1]: Using HYP init bounce page @79b81000 [ 7.114066] kvm [1]: interrupt-controller@1c84000 IRQ25 [ 7.114480] kvm [1]: timer IRQ27 [ 7.114504] kvm [1]: Hyp mode initialized successfully [ 7.116311] lock super standby defaultly! [ 7.116332] lookup_scene_lock_name: new scene lock super_standby [ 7.116348] scene_lock_init name=super_standby [ 7.116363] scene_lock: super_standby, type 5, count 1 [ 7.116786] audit: initializing netlink socket (disabled) [ 7.116848] type=2000 audit(0.150:1): initialized [ 7.117459] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 7.117940] VFS: Disk quotas dquot_6.5.2 [ 7.118057] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 7.118472] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 7.119002] NFS: Registering the id_resolver key type [ 7.119057] Key type id_resolver registered [ 7.119071] Key type id_legacy registered [ 7.119091] Installing knfsd (copyright © 1996 okir@monad.swb.de). [ 7.119243] NTFS driver 2.1.30 [Flags: R/W]. [ 7.119414] fuse init (API version 7.22) [ 7.119612] msgmni has been set to 1961 [ 7.120569] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 7.120674] io scheduler noop registered [ 7.120689] io scheduler deadline registered [ 7.120723] io scheduler cfq registered (default) [ 7.121575] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 7.121606] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n [ 8.027497] console [ttyS0] enabled [ 8.031753] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI [ 8.038567] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI [ 8.045459] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI [ 8.052347] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI [ 8.059252] misc dump reg init [ 8.062744] [drm] Initialized drm 1.1.0 20060810 [ 8.072194] brd: module loaded [ 8.077851] loop: module loaded [ 8.081547] sunxi-bt bt.27: Missing bt_power. [ 8.086314] sunxi-bt bt.27: bt_power_name ((null)) [ 8.091567] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io) [ 8.097692] sunxi-bt bt.27: bt_rst gpio=356 mul-sel=1 pull=-1 drv_level=-1 data=0 [ 8.106305] sunxi-bt bt.27: clk not config [ 8.110858] sunxi-bt bt.27: block state already is 1 [ 8.116470] sunxi-wlan wlan.26: wlan_busnum (1) [ 8.121438] sunxi-wlan wlan.26: Missing wlan_power. [ 8.126774] sunxi-wlan wlan.26: wlan_power_name ((null)) [ 8.132595] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io) [ 8.139084] sunxi-wlan wlan.26: wlan_regon gpio=354 mul-sel=1 pull=-1 drv_level=-1 data=0 [ 8.148440] sunxi-wlan wlan.26: wlan_hostwake gpio=355 mul-sel=6 pull=-1 drv_level=-1 data=0 [ 8.158077] sunxi-wlan wlan.26: clk not config [ 8.163527] tun: Universal TUN/TAP device driver, 1.6 [ 8.169052] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 8.176412] WARNING: Get ephy clock is failed [ 8.181498] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 8.188741] get ehci0-controller drv_vbus_gpio is fail [ 8.194381] get ehci0-controller, regulator_io is no nocare [ 8.200533] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000b80c90, 0x:ffffff800007a000, irq_no:68 [ 8.213815] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 8.223742] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1 [ 8.233572] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0004cdff8 [ 8.258202] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00 [ 8.266236] hub 1-0:1.0: USB hub found [ 8.270361] hub 1-0:1.0: 1 port detected [ 8.274780] scene_lock_init name=ehci_standby [ 8.279639] get ehci1-controller drv_vbus_gpio is fail [ 8.285259] get ehci1-controller, regulator_io is no nocare [ 8.291406] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000b80ee0, 0x:ffffff80000aa000, irq_no:6a [ 8.304685] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 8.314611] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2 [ 8.324293] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc0004cdff8 [ 8.346756] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00 [ 8.354687] hub 2-0:1.0: USB hub found [ 8.358809] hub 2-0:1.0: 1 port detected [ 8.363216] scene_lock_init name=ehci_standby [ 8.369083] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 8.375978] get ohci0-controller drv_vbus_gpio is fail [ 8.381612] get ohci0-controller, regulator_io is no nocare [ 8.387750] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000b807f0 [ 8.397988] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 8.407529] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3 [ 8.416985] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0004d1798 [ 8.478926] hub 3-0:1.0: USB hub found [ 8.483035] hub 3-0:1.0: 1 port detected [ 8.487451] scene_lock_init name=ohci_standby [ 8.492268] get ohci1-controller drv_vbus_gpio is fail [ 8.497904] get ohci1-controller, regulator_io is no nocare [ 8.504029] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000b80a40 [ 8.514265] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 8.523796] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4 [ 8.533254] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0xffffffc0004d1798 [ 8.596983] hub 4-0:1.0: USB hub found [ 8.601090] hub 4-0:1.0: 1 port detected [ 8.605498] scene_lock_init name=ohci_standby [ 8.610531] usbcore: registered new interface driver usb-storage [ 8.617145] usbcore: registered new interface driver ums-alauda [ 8.623656] usbcore: registered new interface driver ums-cypress [ 8.630252] usbcore: registered new interface driver ums-datafab [ 8.636858] usbcore: registered new interface driver ums_eneub6250 [ 8.643650] usbcore: registered new interface driver ums-freecom [ 8.650242] usbcore: registered new interface driver ums-isd200 [ 8.656747] usbcore: registered new interface driver ums-jumpshot [ 8.663444] usbcore: registered new interface driver ums-karma [ 8.669845] usbcore: registered new interface driver ums-onetouch [ 8.676548] usbcore: registered new interface driver ums-realtek [ 8.683154] usbcore: registered new interface driver ums-sddr09 [ 8.689652] usbcore: registered new interface driver ums-sddr55 [ 8.696158] usbcore: registered new interface driver ums-usbat [ 8.702667] usbcore: registered new interface driver usbserial [ 8.709070] usbcore: registered new interface driver usbserial_generic [ 8.716239] usbserial: USB Serial support registered for generic [ 8.723011] mousedev: PS/2 mouse device common for all mice [ 8.729509] input: sunxi-keyboard as /devices/virtual/input/input0 [ 8.736752] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0 [ 8.744209] sunxi-rtc 1f00000.rtc: RTC enabled [ 8.749253] i2c /dev entries driver [ 8.790103] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1 [ 8.803584] sunxi budget cooling probe start ! [ 8.808468] CPU freq cooling register Success [ 8.813272] CPU hotplug cooling register Success [ 8.818397] CPU budget cooling register Success [ 8.823569] sunxi gpu cooling probe start ! [ 8.828148] CPU gpu cooling register Success [ 8.835587] cpuidle: using governor ladder [ 8.840077] cpuidle: using governor menu [ 8.845049] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 18:44:41 [ 8.857922] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none [ 8.864596] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none [ 8.871363] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc [ 8.878457] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found [ 8.884644] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found [ 8.891338] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166. [ 8.897036] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.908003] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator [ 8.927316] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 8.956860] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000be000 irq:92 [ 8.964083] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jul 19 2016 at 18:44:41 [ 8.976949] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string [ 8.983897] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string [ 8.990948] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string [ 8.997996] get() with no identifier [ 9.001900] get() with no identifier [ 9.005803] get() with no identifier [ 9.009716] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found [ 9.015909] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found [ 9.022191] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found [ 9.028810] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.039774] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator [ 9.056042] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !! [ 9.063516] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !! [ 9.065073] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.081604] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.084771] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000d6000 irq:93 [ 9.085316] usbcore: registered new interface driver usbhid [ 9.085317] usbhid: USB HID core driver [ 9.110659] usbcore: registered new interface driver snd-usb-audio [ 9.112580] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.114705] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.115516] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.116325] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.117134] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !! [ 9.117761] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 9.117802] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 9.120172] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B [ 9.140986] mmc0: host does not support reading read-only switch. assuming write-enable. [ 9.142838] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B [ 9.142878] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B [ 9.142974] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B [ 9.142993] mmc0: new high speed SDHC card at address 59b4 [ 9.238510] mmcblk0: mmc0:59b4 NCard 7.48 GiB [ 9.244135] sndhdmi sound.7: sndhdmi <-> 1c22800.daudio mapping ok [ 9.244373] mmcblk0: p1 p2 [ 9.254942] TCP: cubic registered [ 9.255279] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 9.256089] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !! [ 9.256107] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.258506] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.260321] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !! [ 9.261128] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.261932] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.262739] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.263543] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !! [ 9.264350] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.265154] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.265959] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.266763] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !! [ 9.266777] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 9.267606] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !! [ 9.267620] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B [ 9.383128] NET: Registered protocol family 10 [ 9.388637] sit: IPv6 over IPv4 tunneling driver [ 9.394040] NET: Registered protocol family 17 [ 9.398947] 8021q: 802.1Q VLAN Support v1.8 [ 9.403570] Key type dns_resolver registered [ 9.408413] Registering SWP/SWPB emulation handler [ 9.413927] registered taskstats version 1 [ 9.419269] Key type encrypted registered [ 9.423668] AppArmor: AppArmor sha1 policy hashing enabled [ 9.430501] sunxi-rtc 1f00000.rtc: setting system clock to 2016-07-19 23:53:07 UTC (1468972387) [ 9.440699] input: sunxi-ths as /devices/virtual/input/input2 [ 9.447119] thermal thermal_zone0: failed to read out thermal zone 0 [ 9.454439] ALSA device list: [ 9.457680] #0: sndhdmi [ 9.460966] Freeing unused kernel memory: 520K (ffffffc0009b7000 - ffffffc000a39000) [ 9.528203] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities [ 9.537606] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities [ 9.661734] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 9.933213] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 9.947979] systemd[1]: Detected architecture 'arm64'. [ 9.991297] systemd[1]: Set hostname to <pine64>. [ 10.297748] systemd[1]: Expecting device dev-ttyS0.device... [ 10.324665] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 10.333184] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 10.341558] systemd[1]: Starting Remote File Systems (Pre). [ 10.363993] systemd[1]: Reached target Remote File Systems (Pre). [ 10.370718] systemd[1]: Starting Encrypted Volumes. [ 10.393509] systemd[1]: Reached target Encrypted Volumes. [ 10.399464] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 10.408354] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 10.417051] systemd[1]: Starting Paths. [ 10.432880] systemd[1]: Reached target Paths. [ 10.437719] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 10.448040] systemd[1]: Starting Swap. [ 10.472230] systemd[1]: Reached target Swap. [ 10.476931] systemd[1]: Expecting device dev-mmcblk0p1.device... [ 10.501760] systemd[1]: Starting Root Slice. [ 10.521436] systemd[1]: Created slice Root Slice. [ 10.526607] systemd[1]: Starting User and Session Slice. [ 10.550956] systemd[1]: Created slice User and Session Slice. [ 10.557269] systemd[1]: Starting Delayed Shutdown Socket. [ 10.580479] systemd[1]: Listening on Delayed Shutdown Socket. [ 10.586792] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 10.609997] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 10.617643] systemd[1]: Starting Journal Socket (/dev/log). [ 10.639519] systemd[1]: Listening on Journal Socket (/dev/log). [ 10.646041] systemd[1]: Starting udev Control Socket. [ 10.669038] systemd[1]: Listening on udev Control Socket. [ 10.674982] systemd[1]: Starting udev Kernel Socket. [ 10.698560] systemd[1]: Listening on udev Kernel Socket. [ 10.704428] systemd[1]: Starting Journal Socket. [ 10.728078] systemd[1]: Listening on Journal Socket. [ 10.733620] systemd[1]: Starting System Slice. [ 10.757599] systemd[1]: Created slice System Slice. [ 10.763001] systemd[1]: Started File System Check on Root Device. [ 10.769702] systemd[1]: Starting system-systemd\x2dfsck.slice. [ 10.796969] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 10.803861] systemd[1]: Starting system-getty.slice. [ 10.826477] systemd[1]: Created slice system-getty.slice. [ 10.832408] systemd[1]: Starting system-serial\x2dgetty.slice. [ 10.855996] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 10.862933] systemd[1]: Starting Increase datagram queue length... [ 10.887011] systemd[1]: Starting Restore / save the current clock... [ 10.921596] systemd[1]: Mounting Huge Pages File System... [ 10.985740] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 11.013435] [ehci0-controller]: sunxi_usb_disable_ehci [ 11.019074] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000b80c90 [ 11.029431] scene_lock_destroy name=ehci_standby [ 11.032107] systemd[1]: Started Set Up Additional Binary Formats. [ 11.041239] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4 [ 11.047887] usb usb1: USB disconnect, device number 1 [ 11.050469] systemd[1]: Starting Load Kernel Modules... [ 11.059602] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered [ 11.067337] [ohci0-controller]: sunxi_usb_disable_ohci [ 11.075629] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000b807f0 [ 11.077222] systemd[1]: Mounting POSIX Message Queue File System... [ 11.092905] scene_lock_destroy name=ohci_standby [ 11.097960] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4 [ 11.104555] usb usb3: USB disconnect, device number 1 [ 11.110499] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered [ 11.118154] [ehci0-controller]: sunxi_usb_enable_ehci [ 11.126351] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000b80c90, 0x:ffffff800007a000, irq_no:68 [ 11.140754] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 11.150704] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1 [ 11.162058] systemd[1]: Starting udev Coldplug all Devices... [ 11.175678] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000427c48 [ 11.192434] systemd[1]: Mounting Debug File System... [ 11.200393] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00 [ 11.209828] hub 1-0:1.0: USB hub found [ 11.213958] hub 1-0:1.0: 1 port detected [ 11.218398] scene_lock_init name=ehci_standby [ 11.223202] [ohci0-controller]: sunxi_usb_enable_ohci [ 11.225089] systemd[1]: Starting Slices. [ 11.233125] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000b807f0 [ 11.243369] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 11.252955] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3 [ 11.262426] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc039983d50 [ 11.289077] systemd[1]: Reached target Slices. [ 11.308727] systemd[1]: Mounted Debug File System. [ 11.328413] systemd[1]: Mounted POSIX Message Queue File System. [ 11.332697] hub 3-0:1.0: USB hub found [ 11.332710] hub 3-0:1.0: 1 port detected [ 11.332841] scene_lock_init name=ohci_standby [ 11.367837] systemd[1]: Mounted Huge Pages File System. [ 11.397319] systemd[1]: Started Increase datagram queue length. [ 11.426808] systemd[1]: Started Restore / save the current clock. [ 11.456325] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 11.503316] systemd[1]: Starting Create Static Device Nodes in /dev... [ 11.527700] systemd[1]: Starting Syslog Socket. [ 11.544896] systemd[1]: Listening on Syslog Socket. [ 11.550455] systemd[1]: Starting Journal Service... [ 11.594133] systemd[1]: Started Journal Service. [ 11.609764] cfg80211: Calling CRDA to update world regulatory domain [ 11.776312] RTL871X: module init start [ 11.780426] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844 [ 11.787935] RTL871X: build time
If you like my work be sure to check out my site or wish to donate to the cause
Cheers
07-19-2016, 08:06 PM
Sweet! Can't wait!
07-20-2016, 03:49 AM
Double Rainbow?
07-20-2016, 04:04 AM
This does look good indeed.
From what I think I can understand from the code is that the Ethernet port looks functional! WLAN, VLAN support is awesome as per code mentions! A lot more there to read and understand... Woo hoo!!! Keep it up! Awesome Job! Regards, Vinod
07-27-2016, 01:54 AM
What I understood from various discussions on IRC and the internet: there is a kernel space driver for Mali OpenGL ES, there is a user space driver for Mali OpenGL ES, startx fails because it searches for OpenGL(but the driver only offers OpenGL ES). The GUI/desktop/window manager must be configured to start without hardware acceleration(most GUI/desktop/window managers use OpenGL, very few started development for OpenGL ES). Only applications written for OpenGL ES can use hardware acceleration. Currently there is a lack of info (should Allwinner provide the info???) on configuring the xorg.conf to start without HW acceleration but to offer to applications OpenGL ES HW acceleration.
That is what I understood. I might be wrong.
07-29-2016, 10:16 AM
Folks the mali is just about ready for deployment.
Just one more thing to hammer out and we are golden
Cheers
07-29-2016, 10:18 AM
Awesome! Can't wait!
07-29-2016, 10:29 AM
Nice job! I can't wait!
Brand New LCD not working | adamjedgar | 3 | 6,602 |
03-11-2017, 12:20 AM Last Post: simplexdan |
Pine64+: 3 working, 1 shows nothing on tv | zumtra | 1 | 3,984 |
07-30-2016, 05:47 PM Last Post: tllim |
