slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#51
Updated Slackware Aarch64 Miniroot (ROCK64) 20190201 on Wiki and PINE64 Installer.
Updated Slackware Aarch64 XFCE (ROCK64) 20190201 on Wiki and PINE64 Installer.
updated kernel (ayufan 4.4.167-1213)
kernel for slarm64:
kernel-firmware-rk3328-4.4.183-aarch64-1mara.txz
kernel-headers-rk3328-4.4.183-aarch64-1mara.txz
kernel-modules-rk3328-4.4.183-aarch64-1mara.txz
kernel-rk3328-4.4.183-aarch64-1mara.txz
update packages:
1. download all listed files
2. sudo upgradepkg kernel-*.txz
update:
- kernel 4.4.183
- update all packages Sat Jun 22 19:14:18 UTC 2019
slarm64-current-aarch64-base-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz
slarm64-current-aarch64-base-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz
slarm64-current-aarch64-xfce-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz.md5
Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
Updated Slackware Aarch64 XFCE (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
(07-02-2019, 08:16 PM)pineadmin Wrote: Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image.
I used to have a  PC-based slackware router that I wanted to reimplement on the rock64. Unfortunatelly, I had to go with Armbian stretch at the end, because I could not use slackware, but I would like to go back to slackware if possible. How stable/reliable slackware on the rock64? Have you had good feedback? I'll try the next release. When will you have it?
Thanks,
Karl
Thanks,
Karl
Please ensure the Micro SD Card is UHS-1 class. If used lower class such as Class 2 Micro SD Card is too slow to use and can get the whole system runs in to low performance or sometimes crash.
Thanks,
pineadmin....
Thanks,
Karl
Thanks,
pineadmin....
This is what I used:
Kingston Canvas Select 16GB microSDHC Class 10 microSD Memory Card UHS-I 80MB/s R Flash Memory Card with Adapter (SDCS/16GB)
Quote:I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image.
I will look at performance over a long period.
while the problem of the correct booting and operation of the system from the SDcard with the eMMC module connected is noticed.
when disconnecting the eMMC boot and works fine
I don't have an eMMC module.
I'll give it another try with another SD card, and if that doesn't work, I'll have to throw in the towel.
KarlF,
Left the board to work the day the image of the sfke, no problems were detected, SDCard samsung SD EVO PLUS 32Gb.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 133 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,322 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 321 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 593 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 591 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,205 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 578 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 631 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,821 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 915 08-29-2022, 01:22 PM
Last Post: ramprasad
