Pine H64 feature request(s)
Since the H64 is still in beta, that leaves room for changes, right? One that would be very useful is the inclusion of a SIM card slot, so I can use LTE modems. I think this is only required for systems that are GSM, such as AT&T and T-Mobile in the USA, and not Verizon and Sprint. I'll be testing this out soon.
If you don't think there's enough demand, maybe you can just change the PCB layout to leave me holes/pads to solder a SIM socket to.
The other thing that would be useful is retaining clips for the mini-PCIe slot. Without them, I am worried that the only thing physically holding the card in is the socket itself, and this doesn't seem like it would be very reliable. I note some holes in seemingly appropriate places to install such a clip, and I'll do this on the board I have (once I source the clip).
Please let me know about these, because I have to figure out some workaround if you're not going to include them in production boards.
Regards,
Robert K.
(02-20-2018, 03:00 AM)RWK Wrote: Hello,
Regards,
Robert K.
We have SIM card discussion on PINE H64 board at IRC few months ago, and I still prefer not to include in the PINE64 board. If you interest to use LTE modem with Sim card slot, there is minipcie to m.2 with sim card slot already available. Here is the ebay link: https://www.ebay.com/itm/M-2-NGFF-Key-B-...PS-LTE-1pc
We will check on the retaining clips suggestion. However, seems like such clips easily to break off and worry that this can increase tech support and also RMA.
  pine vacuum cleaner and door phone norayr 3 603 01-16-2024, 02:31 AM
Last Post: hanajijang
  Android OS that supports LCD touch panel (pine a64) Spekboy 0 369 01-14-2024, 01:41 PM
Last Post: Spekboy
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 610 09-21-2023, 07:52 AM
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 797 08-30-2023, 04:23 PM
  Pine Desktop PowerSupply wont power on BSharp 5 1,795 08-29-2023, 08:06 AM
Last Post: chickenplusone
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,523 07-24-2023, 03:21 PM
Last Post: Omnios
  Pine.org very poor review rma00 6 1,717 06-30-2023, 12:52 PM
Last Post: gregb49
  Cryptocurrency payment option and Pine hardware wallet, any thoughts? ohuw67 11 10,048 03-03-2023, 01:18 AM
Last Post: user641
  What about a Pine digital audio player? ClairelyClaire 4 2,432 02-06-2023, 11:17 PM
Last Post: nixcamic
  New product idea: Pine Glasses Blathers 2 2,797 12-02-2022, 09:51 PM
Last Post: erikzoltan
