Mate Kiosk Problem on Rock64
Brick
Hi gang.  I have the strangest problem and figured I'd see if any of you have experienced it.  I'm using the latest xenial mate image on a high quality sd card with plenty of power.
For those of you who don't know this, chromium browser can be run with a -kiosk flag that fullscreens it and takes away the location bar. You can still close it with altf4, but otherwise you'd never know it's a browser.
On this Rock64 image, right "out of the box", when you put it into kiosk mode and autolaunch, when it boots, it's hidden, and there is a tab of it down in the tray.  It's there, technically. You can grab it sometimes and move it, without being able to see it, and the computer is locked until you hit altf4 and close chromium.
And get this, on two occasions, it didn't happen and it booted into chromium fine.
It's like it can't render it, and this is the 4g model of the rock64.
Debian mate doesn't do it.
Hi again. I still haven't found an answer to this problem. There is a similar thread on github and it didn't really go anywhere.
https://github.com/ayufan-rock64/linux-build/issues/52
Anyone have any ideas?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 149 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,353 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 333 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 610 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 606 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,356 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,337 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 590 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 649 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,302 12-07-2022, 08:22 PM
Last Post: luminosity7
