Ethernet works on Arch Linux. Nothing elese
I got 2 gb board and was able to install Remix OS (dd), Arnroid(dd) and arch Linux(dd).
Could not get any kind of wifi dongle working.
Remix OS reboots in a loop, which ive seen others talk about.
Anroid Lollipop could not get any kind of ethernet or wifi.
Arch Linux is the only OS i could get connected and am posting this thread from it.
Update: well 10 minutes later connection went dead.
+1 here for a 2GB pine64+ for which Ethernet doesn't work in Android. In case it helps someone, the router I connected it to showed a 100BT connection on that link of the built-in switch, whereas everything else on that switch showed up as gigabit. Between that and the solid green light on the ethernet port, it appears to work electrically, but Android doesn't see it. With respect to power, I'm using a 2.5A 5V power supply. Have yet to give Linux a go.
Having the same problem here. No ethernet on Android or Remix, Wifi does work, but that is not workable for me. Does anyone even recognize that this is a problem?
This product was touted as something superior to the Raspberry Pi. I'm sorry, I'm just not seeing it.
"Could not get any kind of wifi dongle working."
Third party dongles do not work out of the box.
Which img(s) did you burn (dd or remix) ? what PSU are you using and what is the AWG of the micro USB cable ?
same issue.
Running android-ver5.1.1-lcd-version-20160603-pine64-8GB.img
Got my LCD screen plugged in with an ethernet cable as well. No internet
  Ethernet port down afert 1 day jeda 0 642 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 5,322 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 24,559 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 16,490 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 113,663 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 15,759 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,390 08-17-2016, 05:44 PM
