First Lakka image for Rock64!
Smile
[edit 04/06/2018]: As Ntemis pointed out, newer Lakka nightly builds can be downloaded for the Rock64 from here.
The good people at Lakka have released an image for the Rock64.
Please download it directly from their server.
Its a good day! Smile I can't wait to try tonight.
I have just try out and this is awesome !!!
does joypad/joystick work well?
(11-15-2017, 05:37 PM)dkryder Wrote: does joypad/joystick work well?
Most of my retro controllers worked fine (among them 8Bitdo NES30 Pro and Buffalo SNES) and so did generic and authentic Xbox 360 controllers. PS3 SixAxis controller didn't work.
To add to Luke's comment, I could not make my Xbox One controller work, nor did my Logitech F310 USB controller. However my NES30 Pro and my Mayflash GameCube to USB adaptor and WaveBird controller worked fantastically.
Thanks dudemo, just signed up on their forum to relay this to the developers.
Edit: iNNEXT controllers don't work either
You need to just copy over the config files from the master github. I'll search and then post
Wiki - http://www.lakka.tv/doc/Input-settings/
Github with files - https://github.com/libretro/retroarch-jo...aster/udev
(11-16-2017, 07:11 AM)KryPtAlIvIaN Wrote: You need to just copy over the config files from the master github. I'll search and then post
Huge thumbs up!
still doesn't recognise those controllers
In the past, I've copied and pasted the config values from your controller config file into the retroarch.cfg and it worked. Have you restarted?
  Xen hypervisor on Rock64 tumbleweed 6 9,684 Yesterday, 09:25 AM
Last Post: darkfader
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 9 15,793 07-20-2025, 01:00 PM
  Rock64 - not booting after Armbian update helpmerock 6 3,672 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,359 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,487 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,517 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 68,642 09-01-2024, 06:43 AM
Last Post: RaymondDay
  Rock64 v2 - did not work song / audio sqw200zu 2 4,437 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,608 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 3,076 11-21-2023, 08:33 AM
Last Post: as365n4
