LCD and HDMI - any GNU/Linux version do this?
Having used the Pine 2.0 Beta 3 tool to place images on microSD cards I can not seem to find one that uses both the HDMI and LCD screen as video output.   (or get me to a login prompt with the LCD ribbon cable plugged in)
The Xenial MATE version as presented by the tool will boot to a Unix login (or looked like it - didn't actually log in) on the HDMI without the LCD cabled in, but with the LCD in AND a monitor plugged in the SOPINE/baseboard model A.  And by not boot I mean it shuts off.
It seems the functionality exists as the Android 6.0.1 (non eMMC) version will allow for the LCD and the HDMI to work at the same time.  (I did not try Android 5 and Android 7 did not allow operation of the LCD)   As the limitation seems to be software, is there a GNU/Linux version which would work with both video output methods?
(10-18-2017, 01:22 PM)freebsd Wrote: It seems the functionality exists as the Android 6.0.1 (non eMMC) version will allow for the LCD and the HDMI to work at the same time.  (I did not try Android 5 and Android 7 did not allow operation of the LCD)   As the limitation seems to be software, is there a GNU/Linux version which would work with both video output methods?
At the moment I believe that gnu+linux is one or the other.
(10-19-2017, 02:25 AM)MarkHaysHarris777 Wrote: At the moment I believe that gnu+linux is one or the other.
I've been told by a little birdie that a setting exists in the configuration file which will address the issue in Xenial MATE.
Is that going to be found in the pinebook section?
  PINE A64-LTS enable I2S on Linux toadShepard 0 934 08-08-2024, 12:09 PM
Last Post: toadShepard
  No HDMI output on standard Debian install / no boot sagada 2 6,612 09-06-2020, 03:54 AM
Last Post: kuleszdl
  NEMS Linux for LTS/ SOPine Luke 1 7,413 05-09-2019, 05:46 PM
Last Post: pineadmin
  Xfce 4.12 on Pine64LTS is possibly the best linux build! wombat 0 3,514 02-17-2019, 07:47 AM
Last Post: wombat
  Arch Linux mainline XFCE (PINE A64-LTS / SOPINE) pineadmin 1 9,339 11-09-2018, 03:07 AM
  No boot on any Linux image :/ oxomoxo 2 4,920 08-11-2017, 09:44 AM
Last Post: oxomoxo
