10-10-2017, 07:30 PM
What power supply I need to purchase for Pine A64 LTS board ?
Power supply for Pine A64 LTS
10-10-2017, 08:24 PM
(10-10-2017, 07:30 PM)panah87 Wrote: What power supply I need to purchase for Pine A64 LTS board ? This is very well documented on this forum in multiple threads; please see this link particularly: I prefer the Raspberry PI power adapter due to its very good two wire cable; cut the cable to no more than one meter, and adapt to the euler bus pin(6 -ground) pin(4 +5v). (or mount barrel connector, see below) The Rock64 power supply is also quite good 5v @3A 3000ma. It has a barrel connector ! I'm not sure if the LTS board has the barrel connector yet... if not you can add it and wire to the euler bus, otherwise if the LTS board has the barrel connector the Rock64 power supply will just plug it !
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! )
10-11-2017, 12:27 AM
(10-10-2017, 08:24 PM)MarkHaysHarris777 Wrote:(10-10-2017, 07:30 PM)panah87 Wrote: What power supply I need to purchase for Pine A64 LTS board ? the LTS board using 3.5mm OD/1.35mm ID barrel type connector.
10-11-2017, 04:01 AM
(10-11-2017, 12:27 AM)tllim Wrote:(10-10-2017, 08:24 PM)MarkHaysHarris777 Wrote:(10-10-2017, 07:30 PM)panah87 Wrote: What power supply I need to purchase for Pine A64 LTS board ? Thank you for confirming tllim !
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! ) |
PINE A64-LTS v2 - Can't get WiFi to work | Voidwatcher | 2 | 1,666 |
04-01-2023, 10:29 PM Last Post: Voidwatcher |
Power lead / RS232c - DIN Project | JohnnySSH | 3 | 8,642 |
08-15-2019, 07:02 PM Last Post: tllim |
