10-03-2017, 11:36 AM
I've seen mention that some have run Plex, but I can't figure out which image they are referring to. Is it available?
Is Plex on any of the images?
10-03-2017, 11:38 AM
No, you have to install it yourself. Only Kodi is available, but i wouldn't recommend it right now.. If you install plex, leave feedback.
Trimis de pe al meu Nexus 6 folosind Tapatalk
10-06-2017, 06:52 AM
I got the plex from this version. The "64-99".
https://github.com/ayufan-rock64/android.../tag/0.3.6
10-13-2017, 09:31 AM
(10-03-2017, 11:38 AM)skyway Wrote: No, you have to install it yourself. Only Kodi is available, but i wouldn't recommend it right now.. If you install plex, leave feedback. Leaving feedback of my experience. I tried several different OS images before I finally got one to work with Plex, but it turned out to be actually very easy once I used the right image. I flashed the latest Artful armhf test build by Auyfan, then just apt-get update, apt-get install plexmediaserver-installer, and it worked flawlessly. In a web browser, open https://[rock64_ip_address]:32400/manage to access the web interface. I also needed to apt-get install ntfs-3g to mount my ntfs hard drive as writable. I was also able to install Oracle Java 8 from the existing repos and openhab using the Ubuntu instructions on the openhab website.
10-16-2017, 03:32 AM
The best is to use `openmediavault/armhf`. It has Plex easy to install via Web panel.
Homepage: https://ayufan.eu
Releases: Rock/Pro 64/Pinebook Pro: Linux; Chromium OS So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1 Buy me a Beer
12-28-2017, 01:04 PM
(10-16-2017, 03:32 AM)ayufan Wrote: The best is to use `openmediavault/armhf`. It has Plex easy to install via Web panel. I've installed OMV then enabled OMV-Extras For Plex repo then i tried installing the Plex Plugin but i get this Code: The following packages have unmet dependencies:
12-28-2017, 02:53 PM
(12-28-2017, 01:04 PM)Jxck Wrote:I've figured it out i didn't need to enable the repo and i tried it worked!(10-16-2017, 03:32 AM)ayufan Wrote: The best is to use `openmediavault/armhf`. It has Plex easy to install via Web panel. |
Rock64-4gb,Armbian Debian Stretch: Plex, Radarr, NZBGet and Sickchill WOW | Baracuda2 | 1 | 3,051 |
02-27-2019, 03:34 PM Last Post: Luke |
Archive of past Rock64 Linux Images? | wbecks | 3 | 4,036 |
01-03-2018, 05:24 PM Last Post: dkryder |
