Frustrating - Is there any 'good' OS?
#21
(07-05-2018, 08:12 AM)ayufan Wrote: I might push Bionic based on 3.10 kernel if this is helpful for anyone Smile
Perhaps with a LXDE desktop - because its so nice and lighweight ? Would be great, especially since the Pinebook relaunched ...
#22
I dont know why the "actual" armbian-link
[June 19] Armbian (5.46) Pinebook
https://showthread.php/?tid=4592
doesnt work, but I wish in the near future something with a newer kernel than 3.10 Smile
Like the armbian 5.51 with Kernel 4.17.3 out of the armbian-build-system...
Its without GUI and Wifi doesnt work, but a USB-Ethernet does get the network going Smile
(07-06-2018, 05:22 AM)guidol Wrote: I dont know why the "actual" armbian-link
I'm having a good experience at the moment with Netrunner. I have a post over on that thread on how to get it to update from the Debian repos, which enables the wifi to auto-connect. If you combine that with the sleep "workaround" script also mentioned in that thread, you have a system that works pretty well. The only remaining problem is that sound doesn't return after sleep (and sleep for some reason leaves the green power light on). I just tested that feature with Q4OS, and it has the same problem with sound.
