Pinebook Linux Power-Down Procedure
Information
Greetings,
The Pinebook Linux Power-Down Procedure that has been found to be most effective (although not 100% reliable) is to use the "power button" to pull up the shutdown dialogue !
Testing has shown that if the shutdown command happens in a terminal (or serial console), or if it is selected with the mouse from the System menu or the tool-bar the system  correctly hits the systemd target shutdown;  however, the hardware ARISC PMIC does not power off the system.
On the other hand,  if the user will press the actual "power button"  (upper right hand key on the keyboard)  then after the systemd  target shutdown the hardware will correctly (most of the time) power off the hardware.
... but don't trust it,  check it !!
Shy
Good to know! Indeed I've experienced that sometimes a reboot or shutdown doesn't seem to complete properly, will hit the power button only for now to see if indeed proper shutdown is done! Smile
Greetings,
In this segment I have captured the OS shutdown to :  target shutdown ( look for it in the log below );  beginning with the OS unmounting of the Local File Systems (the critical piece of shutdown )!
After this line:
                [  OK  ] Reached target Shutdown.
...  we see the power down console messages ( usually never seen by human eyes ) and a long string of messages beginning with this line:
                 [48025.784817] Power down.   ( look for "hello boot0 starting" )
... and culminating in this line ultimately if the hardware actually powers OFF :
                 [      8.036]power off set power off vol to default
Lowly humans get to see a brief  battery charging icon on the screen at this point ( boot0 arisc uboot ).
Its amazing what we can learn about the system ( hardware and software ) by studying the serial console logs !
[  OK  ] Stopped target Local File Systems.
        Unmounting /run/user/1000...
        Unmounting /boot...
[  OK  ] Removed slice system-systemd\x2dbacklight.slice.
[  OK  ] Unmounted /run/user/1000.
[  OK  ] Unmounted /boot.
[  OK  ] Stopped File System Check on /dev/mmcblk0p1.
[  OK  ] Removed slice system-systemd\x2dfsck.slice.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Stopped Remount Root and Kernel File Systems.
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 2, MPID 0x0, State ON
INFO:      AffInst: Level 1, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State OFF
INFO:      AffInst: Level 0, MPID 0x2, State OFF
            ( console messages stop here if the pinebook is unplugged )
HELLO! BOOT0 is starting!
boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x0000a101
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.1
start ddr type auto scan mode
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1280 mv
DRAM init OK
lpddr3 try success
DRAM Type = 7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 408 MHz
DRAM zq value: 003939b9
DRAM dual rank full DQ gate training OK
DRAM size = 2048 MB
DRAM init ok
dram size =2048
card boot number = 2, boot0 copy = 0
card no is 2
sdcard 2 line count 8
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 2***
[mmc]: mmc 2 cmd 8 timeout, err 00000100
[mmc]: mmc 2 cmd 8 err 00000100
[mmc]: mmc 2 send if cond failed
[mmc]: mmc 2 cmd 55 timeout, err 00000100
[mmc]: mmc 2 cmd 55 err 00000100
[mmc]: mmc 2 send app cmd failed
[mmc]: ***Try MMC card 2***
[mmc]: MMC 5.0
[mmc]: HSDDR52/DDR50 8 bit
[mmc]: 50000000 Hz
[mmc]: 14800 MB
[mmc]: ***SD/MMC 2 init OK!!!***
sdcard 2 init ok
The size of uboot is 000f8000.
sum=dda0f53d
src_sum=dda0f53d
0x00000002 0x00000000
0x00000000 0x00000000
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x0000a400 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019c00 success
set arisc reset to de-assert state
Ready to disable icache.
é  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):864ef11
NOTICE:  BL3-1: Built : 21:59:22, May  8 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x4a000000
INFO:    BL3-1: Next image spsr = 0x1d3
U-Boot 2014.07-00014-gc616876 (May 30 2017 - 18:44:41) Allwinner Technology
uboot commit : c616876a3e07117d9bf1a5fdadbc7e7c233c4f34
rsb: secure monitor exist
[      0.433]pmbus:   ready
[      0.436][ARISC] :arisc initialize
[      0.969][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc_para size:1a8
[SCP] :arisc version: [v0.1.76]
[SCP] :sunxi-arisc driver v1.10 is starting
[      1.162][ARISC] :sunxi-arisc driver startup succeeded
[      1.214]PMU: AXP81X
[      1.216]PMU: AXP81X found
bat_vol=4180, ratio=100
[      1.224]PMU: dcdc2 1100
[      1.227]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
device_type = 3253, onoff=1
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1100, onoff=1
dcdc6_vol = 1100, onoff=1
aldo1_vol = 2800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dldo1_vol = 3300, onoff=0
dldo2_vol = 2500, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 3300, onoff=1
eldo1_vol = 1800, onoff=1
eldo2_vol = 1800, onoff=0
eldo3_vol = 1800, onoff=0
fldo1_vol = 1200, onoff=0
fldo2_vol = 1100, onoff=1
gpio0_vol = 3100, onoff=1
vbus not exist
normal dc exist, limit to dc
run key detect
no key found
no uart input
DRAM:  2 GiB
fdt addr: 0xb6eb99c0
Relocation Offset is: 75f0c000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[      1.588]start
drv_disp_init
init_clocks: finish init_clocks.
fdt_get_one_gpio lcd0.lcd_gpio_2 fail
fdt_get_one_gpio lcd0.lcd_gpio_3 fail
fdt_get_one_gpio lcd0.lcd_gpio_scl fail
fdt_get_one_gpio lcd0.lcd_gpio_sda fail
pwm_request: reg = 0x1c21400.pchip->pwm = 0
reg_busy_offset=0, reg_busy_shift = 0, reg_enable_offset = 0
request pwm success, pwm = 0!
sunxi_pwm_config: reg_shift = 0, reg_width = 4, prescale temp = 20, pres=0
PWM _TEST: duty_ns=976562, period_ns=5000000, freq=200, per_scal=1, period_reg=3
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
boot_disp.output_disp=0
boot_disp.output_type=1
boot_disp.output_mode=4
fetch script data boot_disp.auto_hpd fail
disp0 device type(1) enable
disp 0, clk: pll(560000000),clk(560000000),dclk(80000000) dsi_rate(560000000)
    clk real:pll(556875000),clk(556875000),dclk(79553571) dsi_rate(0)
enable power vcc-mipi, ret=0
enable power vcc-hsic-12, ret=0
enable power vcc-lvds, ret=0
enable power vcc-pd, ret=0
[      3.178]end
workmode = 0,storage type = 2
[      3.183]MMC:        2
[mmc]: mmc driver ver 2015-06-03 13:50:00
[      3.194]
lcd_edp_tx_rate=2,
lcd_edp_tx_lane=1,
lcd_edp_colordepth=1,
lcd_model_name=2
[      3.204]ANX9807 Chip found
[      3.310]..................................clock is detected.
[      3.339]..................................clock is stable.
sunxi_pwm_config: reg_shift = 0, reg_width = 4, prescale temp = 70, pres=0
PWM _TEST: duty_ns=996094, period_ns=5000000, freq=200, per_scal=1, period_reg=7
[mmc]: get sdc_ex_dly_used 2, use auto tuning sdly
[mmc]: card2 io is 1.8V.
SUNXI SD/MMC: 2
[mmc]: start mmc_calibrate_delay_unit, don't access device...
[mmc]: delay chain cal done, sample: 200(ps)
[mmc]: delay chain cal done, ds: 200(ps)
[mmc]: media type 0x0
[mmc]: ************Try SD card 2************
[mmc]: mmc 2 cmd 8 timeout, err 100
[mmc]: smc 2 err, cmd 8,  RTO
[mmc]: mmc 2 close bus gating and reset
[mmc]: mmc 2 mmc cmd 8 err 0x00000100
[mmc]: mmc send if cond failed
[mmc]: mmc 2 cmd 55 timeout, err 100
[mmc]: smc 2 err, cmd 55,  RTO
[mmc]: mmc 2 mmc cmd 55 err 0x00000100
[mmc]: send app cmd failed
[mmc]: ************Try MMC card 2************
[mmc]: mmc don't support HS400
[mmc]: host caps: 0xef
[mmc]: MID 000088 PSN 0feb0460
[mmc]: PNM NCard  -- 0x4e-43-61-72-64
[mmc]: PRV 4.3
[mmc]: MDT m-8 y-2016
[mmc]: MMC v5.0
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 8 bit
[mmc]: user capacity  : 14800 MB
[mmc]: boot capacity  : 4096 KB
[mmc]: rpmb capacity  : 4096 KB
[mmc]: ************SD/MMC 2 init OK!!!************
[mmc]: ========best spd md: 3-HS200/SDR104, freq: 5-200000000
[mmc]: erase_grp_size      : 0x400WrBlk*0x200=0x80000 Byte
[mmc]: secure_feature      : 0x55
[mmc]: secure_removal_type : 0x9
[mmc]: EOL Info(Rev blks): Normal
[mmc]: Wear out(type A): 0%-10% life time used
[mmc]: Wear out(type B): 0%-10% life time used
[      4.128]sunxi flash init ok
[mmc]: MMC Device 0 not found
** Bad device mmc 0 **
Using default environment
--------fastboot partitions--------
mbr not exist
base bootcmd=run mmcbootcmd
bootcmd set setargs_mmc
key 0
recovery key high 12, low 10
fastboot key high 6, low 4
no misc partition is found
to be run cmd=run mmcbootcmd
update dtb dram start
update dtb dram  end
serial is: 8400503443181809058e
check for ANX9807
found ANX9807 chip
Pine64 model: pine64-pinebook
PowerBus = 2(0: not exist 1:vBus 2:acBus 3:vBus&acBus)
pre charge mode
sunxi_bmp_charger_display
[mmc]: Has init
[      4.754]---drivers/mmc/mmc.c 2733 mmc_init
89334 bytes read in 7 ms (12.2 MiB/s)
bmp file buffer: 0x41000000, bmp_info.buffer: 47400000
fetch script data boot_disp.output_full fail
screen_id =0, screen_width =1366, screen_height =768
frame buffer address 47400036
set next system normal
drv_disp_exit
[mmc]: mmc exit start
[mmc]: delay chain cal done, sample: 185(ps)
[mmc]: delay chain cal done, ds: 192(ps)
[mmc]: mmc 2 exit ok
[      8.036]power off
At this point the hardware has successfully powered down , and if the Pinebook is plugged in charging begins !
Shy
Greetings Pinebook fans !
... the plot thickens.  Powering down with the "power-button"  and then clicking the "shutdown" button is the best;  but the Pinebook can be successfully powered off from the terminal too !
       sudo poweroff      <==== use this one
  vs
       sudo halt
More likely than not  sudo halt  will leave the Pinebook in a powered up state;  from a hardware perspective.  On the other hand,  sudo poweroff  will more likely than not result in the hardware actually powering off the system.
Shy
  DietPi OS for Pinebook MichaIng 3 5,312 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,516 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 876 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 677 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,541 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,201 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,805 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,201 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,788 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,788 12-25-2020, 04:40 PM
Last Post: ford442
