Armbian - Xenial Desktop (Pinebook)
For release notes, please visit Armbian Website.
Armbian - Xenial Desktop (Pinebook SDCard) 5.32
- THIS IS FOR SDCard BOOT!!!
- MD5 (XZ file): 4d5446a705aa40aeaee03d14971b32ca
Anyone try this out yet? What's the performance like vs ayufan's Ubuntu images?
(07-27-2017, 04:04 AM)jordanjay29 Wrote: Anyone try this out yet? What's the performance like vs ayufan's Ubuntu images?
Haven't tried the newer images yet, but I did try the armbian build some 2 months ago; I felt that the XFCE ran a tad bit faster than mate. I imagine the current image itself has fewer functioning features (as well as experimental pre-release features) than ayufan's builds since Igor is currently away from the lab.
What is the difference between Armbian and Ayufan's Ubuntu? Different kernel but the same packages and repositories?
If they're using the XFCE WM, it will be less memory hungry than the Ubuntu Mate image is, but other than that, one thing to consider is the the Armbian images for the pinebook are still WIP (WorkInProgress), so they're not considered the 'release' grade of other Armbian images yet.
(07-27-2017, 06:00 AM)Wizzard Wrote: What is the difference between Armbian and Ayufan's Ubuntu? Different kernel but the same packages and repositories?
kernel is the same.
kernel is the same.
So the packages and repositories are different? Does it have also different DE, not only XFCE?
armbian devs spent time assuring that the packages they do have work together most of the time as a cohesive unit. you can install any desktop you want if you want to spend the time. quite a few of the armbian devs use headless enviroments.
First impression: it seems pretty quick and mpv seems to play 1080p full screen just fine Smile   but it tested it very briefly   Big Grin
(07-29-2017, 06:56 AM)rookieone Wrote: First impression: it seems pretty quick and mpv seems to play 1080p full screen just fine Smile   but it tested it very briefly   Big Grin
Still using Armbian on the Pinebook and I like it quite a lot! Smile
Have been applying some of the tweaks found on the forum, and also removed nodm and installed lightdm.
Pretty happy with this as user! Smile
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 36 27,739 04-09-2022, 01:44 AM
  Armbian 22.02 Release Announcement TRS-80 0 279 02-28-2022, 05:02 PM
Last Post: TRS-80
  Stock Debian on original Pinebook moonwalkers 1 1,283 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 891 01-04-2022, 09:22 PM
Last Post: irongarment
  Big thanks to Armbian! soupbowl 2 1,001 12-30-2021, 01:36 PM
Last Post: rookieone
  DietPi OS for Pinebook MichaIng 2 2,763 10-22-2021, 02:00 PM
Last Post: MichaIng
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 2,714 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 2,138 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 1,643 12-25-2020, 04:40 PM
Last Post: ford442
Information Manjaro ARM for Pinebook erchache2000 88 71,132 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
