Xenial Mate 0.7.5-88 - LCD off after resume
just tried the Xenial Mate release 0.7.4-86 and 0.7.5-88. Both seem to work mostly fine except for two issues.
If sunxi-drm is enabled then suspend (to RAM) does not work anymore, the device does not fully go to sleep and never resumes.
If sunxi-drm is not enabled then suspend works, also resume mostly seems to work but the LCD stays off (black) and I do not know any way to re-enable it.
Release 0.6.2-77 does properly suspend and resume.
Cheers
  nicole
(07-21-2017, 05:09 PM)nicole.f Wrote: Hi,
Cheers
  nicole
Thanks Nicole. I vaguely keep track of what works and what doesnt on the PB image here.
(07-21-2017, 05:09 PM)nicole.f Wrote: just tried the Xenial Mate release 0.7.4-86 and 0.7.5-88. Both seem to work mostly fine except for two issues.
Thanks for the report Nicole. I think fixes for the backlight are in the works (0.7.5 has changes that that work towards that, anyway), but I'm not sure what's happening with the suspend stuff atm.
Just keep in mine that the 0.7.x series is still flagged Pre-Release, so don't expect it to be too stable just yet Wink
(07-21-2017, 07:55 PM)pfeerick Wrote: but I'm not sure what's happening with the suspend stuff atm.
It is not implemented Tongue
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(07-22-2017, 02:16 PM)ayufan Wrote: It is not implemented Tongue
ayufan! You're supposed to be making things better, not worse! :-P Big Grin Ah, well, I'll let you off the hook, you fixed up the glmark2_es2 crash pre-drm enable and brightness controls Wink
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 109,008 07-17-2019, 01:22 PM
Last Post: catsmile
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 1,900 06-11-2019, 01:36 PM
Last Post: k_mp
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 13,329 05-01-2019, 12:09 PM
Last Post: frank-zappa
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 8,842 12-02-2018, 05:37 AM
Last Post: mikee3000
  Xenial Images (Pinebook) 0.6.2-77 pineadmin 11 16,513 09-24-2018, 03:21 AM
Last Post: erchache2000
  WiFi on Xenial Minimal soupbowl 3 5,109 08-12-2018, 07:54 AM
Last Post: jblakeharris
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 3,072 03-14-2018, 08:43 AM
Last Post: xalius
  Ubuntu Unity 7 on 16.04 Xenial soupbowl 2 4,379 12-03-2017, 01:01 PM
Last Post: soupbowl
  Wifi applet after resume from suspend Luke 13 14,760 10-01-2017, 05:26 AM
Last Post: maya.b
Information How to manage Wifi in xenial-i3 i3wm image UPDATE MarkHaysHarris777 4 6,411 09-14-2017, 12:12 AM
Last Post: dahni
