Bricked Pinebook?
I've tested a few versions of OS'es on the Pinebook so far, and it's been a fun little machine. But two days ago, I was going to install the lates Mate edition, and it stopped writing to eMMC at 30%. I tried again several times, but to no avail. Now it won't boot from SDCard OS'es, and no Linux installers go past 30%. The Android installer just has a blank screen and seems like it just dies. If I try booting it without an SDCard, the screen stays blank with backlight. If I try with any SDCard, regardless of image, the Pinebook logo shows with a contributor greeting on the bottom, but nothing else.
I ordered a 32 gig eMMC a while ago (some 3 weeks), so I'll try changing that once it arrives.
Halp?! Anyone got suggestions to what I should try to wake the Pinebook from it's slumber?
Edit boot.scr (generated from boot.cmd) and disable eMMC completely when booting from SDcard.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
But it should still boot from sdcard just fine? I have random things on my eMMC and that never was an issue so far... head over to chat maybe and we'll see if we can figure something out Smile
Disabling emmc worked. Probably an error on the chip. I can check at work next week.
(05-30-2017, 04:32 PM)CaptainZalo Wrote: Disabling emmc worked. Probably an error on the chip. I can check at work next week.
You might be able to wipe the chip; and start over.
(05-30-2017, 03:53 PM)xalius Wrote: But it should still boot from sdcard just fine? I have random things on my eMMC and that never was an issue so far... head over to chat maybe and we'll see if we can figure something out Smile
That's what I would have thought, but it could be locking something up because things are corrupt, or perhaps if the eMMC is not responding properly at all. Hence why disabling it completely seems to 'cure' it.
Yeah. I hope so. Since the pinebook won't boot with it enabled, I guess I need some kind of adapter. The one we had at work until recently, has been returned to the computer forensics lab, meaning it's out of my reach for quite some time. Can any of you recommend a USB to eMMC-adapter/bridge?
I dont know if its compatible...but the only eMMC adapter I know is the one from Hardkernel (Odroid Computers),
which is a eMMC to MicroSD adapter:
http://www.hardkernel.com/main/products/...5415955758
[Image: 201307232003392244.jpg]
and here is a picture of the backside from the Pinebook eMMC (seems to match) :
[Image: eMMC_back-1.jpg]
Guidol, yea me too.
Anyways, CaptainZalo why not just boot up from SD and then format the eMMC (it mounts on boot) ? See if that gives you any errors. If it doesn't then try reflashing eMMC
edit: Or try put it into FEL (using ayufans boot-tools) and reformat eMMC
(06-01-2017, 09:15 AM)Luke Wrote: Guidol, yea me too.
I ordered an eMMC-to-µSD adapter. I'll need it for one of my other projects anyway. The pinebook is happily running android 7.1 at the moment, and my (3 year old) son is hogging it.
  Dead Pinebook - fix it or spare parts? oloturia 2 2,288 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 979 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,328 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 12,932 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,011 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,651 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,652 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,817 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,773 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,025 11-16-2020, 01:25 AM
Last Post: jay3gg
