Accelerated H.264 and HEVC video decoding with Cedrus
#51
As long as the SoC temp in Linux stays below 80 it's fine without heat sink.
#52
Latest update. Running test 1080p video H264 decoding, measured temperature do not go over 44C with heat sink (modified heat sink - cutted to SoC dimension) just layed on top of it, wthout any termal conductive paste.
#53
(07-03-2016, 11:53 AM)janeku Wrote: Latest update. Running test 1080p video H264 decoding, measured temperature do not go over 44C with heat sink (modified heat sink - cutted to SoC dimension) just layed on top of it, wthout any termal conductive paste.
Please post foto of your colling system. My experiments can be found here: http://forum.pine64.org/showthread.php?t...4#pid14694.
#54
(05-11-2016, 02:03 AM)lenny.raposo-pine64.pro Wrote: ok here is the list of the packages available
https://launchpad.net/~longsleep/+archiv...our-makers
now simple do a sudo apt-get install package_name
Wink
(05-13-2016, 12:18 PM)lenny.raposo-pine64.pro Wrote: sudo -i
apt-get install xserver-xorg-video-fbturbo libump libcedrus1 libvdpau-sunxi1 sunxi-disp-tool
Those packages are missing in Debian.
#55
I am trying to get this working in VLC but i can't seem to get it right. I have tried mplayer using longsleep's script to run the big buck bunny test video and that worked fine. For VLC i tried to force VDPAU decoding in the preferences(under the codec tab) and nothing seems to be happening. Is there some step i am missing?
#56
A little something. I don't know if this can apply to the Pine64-board, but it sure does work on the CHIP (which also use the Cedar VPU).
http://free-electrons.com/blog/support-f...ux-kernel/
#57
(08-30-2016, 05:17 AM)CaptainZalo Wrote: A little something. I don't know if this can apply to the Pine64-board, but it sure does work on the CHIP (which also use the Cedar VPU).
hi Captain !  ... exactly !  Take a look at this.
... what is key, the tree NO ONE is barking up right now,  is a browser that fully supports VDPAU.  VDPAU and the Cedrus project are the key, potentially, for video in gnu+linux without proprietary kernel blobs on the PineA64 (IMHO).
Unfortunately, no such browser exists at the moment (for the PineA64) that supports VDPAU.  But this is a conversation (which longsleep has started many times) that needs to be pursued.
#58
(08-30-2016, 05:26 AM)MarkHaysHarris777 Wrote: Unfortunately, no such browser exists at the moment (for the PineA64) that supports VDPAU.  But this is a conversation (which longsleep has started many times) that needs to be pursued.
Who's responsible for handling this? AllWinner, SBC makers or the true Lunix spirit; communities of all the different flavours of AllWinner based SBCs?
#59
Chrome is a total jackass regarding VDPAU/VA-API acceleration under Linux - they support it under ChromeOS, using all the same libraries and setups - but not under Linux.
Firefox, however, at least has VDPAU/VA-API acceleration through freshplayerplugin, so that should work, in theory.
#60
Flash for arm? Is there such a thing?
From what I read on chromium's mailing list the real problem is that no one is working on a vdpau solution.
As always with open-source  you're free to do it yourself  Angel...... Rrrrright
Edit.... the hardware codec support in chromium OS is done by vaapi, it seems, not by vdpau.
  Video wall? monty1 2 4,763 04-12-2017, 04:34 PM
Last Post: monty1
  pine64 accelerated jpeg decoding jacklau 1 4,106 01-12-2017, 01:12 AM
Last Post: Trizna
  Pine64 accelerated H.264 encoding hngjms 7 12,369 10-18-2016, 03:15 AM
Last Post: pfeerick
  The sunxi transform module is very slow, how to do video rotation? jacklau 0 2,406 09-19-2016, 12:24 AM
Last Post: jacklau
  Video encoding h.265/HEVC tomaThoma 1 6,094 07-02-2016, 11:35 PM
  Question about video acceleration BringItOn 10 15,330 06-23-2016, 10:33 AM
Last Post: ssvb
  Linux accelerated graphics nomadewolf 1 4,439 12-29-2015, 11:26 PM
