Battery level measurement?
Does the board offer a way to measure the battery's output voltage? It would be good to estimate the remaining battery charge.
You can read battery status running Linux just by reading info from sysfs (/sys/class/....) files. You get current, voltage, remaining percentage (the PMIC has a learning battery gauge) and other things...
I wrote this script a while ago to show the various battery bits... if you ignore the colour bits, it shows the sysfs paths for the different stats you can show. It uses bc (sudo apt-get install bc) to show the battery voltage as a decimal number.
Rainbow Lithium battery temperature readout? GregH 0 1,876 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 66,541 07-15-2017, 03:56 PM
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,572 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 26,549 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,816 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 51,847 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,352 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,460 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,360 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 17,936 02-18-2016, 05:17 AM
Last Post: German
