Kernel for A64 git
Did anyone tried usbip? Not sure if it needs extra modules for that. I'm gonna test it later tonight.
(02-14-2016, 03:00 AM)longsleep Wrote: **3.10.101-1-pine64-longsleep-41 (20160516)**
- Tagged as 3.10.101-1-pine64
- Enable XFS, FS2FS and HFS+ as module
- Fix sunxi-ss ahash registration and disable SHA-224
- Enable BLK_DEV_BSG for better udev compatibility
**3.10.101-2-pine64-longsleep-48 (20160521)**
- Tagged as 3.10.101-2-pine64
- Enable various netfilter and namespace features to make LXD happy
- Disable XFS module (not compatible with user namespaces in Kernel 3.10)
- Backported apparmor3
- Enable/changed various additional features to for complete secure container support
First of all, big THANKS! for all your work on this. And now to my question -- is there a chance to get the XFS module back? Maybe if I disable user namespaces? Not sure where user namespaces are used, but if it's only containers stuff, I'd gladly sacrifice it for XFS support.
Yes just rebuild with xfs if you do not need secure containers.
I just pushed a new awesome Kernel release. It brings a security fix, ip multicast support and A64 camera driver changes. For details, see the first post of this thread.
Get 3.10.104-1-pine64-longsleep-103 from https://www.stdin.xyz/downloads/people/l...ges/linux/
Thanks Simon, you rock !
(10-12-2016, 10:01 AM)longsleep Wrote: Yes just rebuild with xfs if you do not need secure containers.
Just for the record and for people with similar use case: I built the kernel with the XFS module and no namespaces and everything works great. Except for new(ish) XFS file system created which cause crash in the XFS module when being mounted. Older XFS file systems work just fine.
@longsleep Simon... thanks for the great work! Don't know what the pine64 would be without your support
I just released a new Kernel build line "pine64gmac" which has a possible fix for the Ethernet Gigabit issue which happens on some boards. The fix is based on a patch provided by tllim (thanks!).
For now consider this a test release and you can switch to the pine64gmac Kernel line easily with
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh) latest gmac
You can switch back to the normal Kernel line with
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh) latest default
(assume the Network still works with the gmac Kernel Smile).
To see what changed:
https://github.com/longsleep/linux-pine6...gmactxonly
If feedback is good, this fix will go into the default Kernel. So let me know how it goes.
To check if the fix is applied on boot:
root@pine64:~# dmesg|grep 'init ephy'
[   16.070919] init ephy for pine64
(10-29-2016, 07:09 AM)longsleep Wrote: I just released a new Kernel build line "pine64gmac" which has a possible fix for the Ethernet Gigabit issue which happens on some boards. The fix is based on a patch provided by tllim (thanks!).
This is super cool! Thanks!
Thanks.
  PineA64+: Audio in 5.0 Kernel puzzles 6 8,769 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 2,873 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 2,565 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 70,808 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,417 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,587 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 3,260 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 18,952 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 4,551 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
  Jackd triggers kernel warning cztian 0 3,457 09-03-2016, 08:16 AM
Last Post: cztian
Users browsing this thread: 7 Guest(s)
