Android 6.0 Tablet and TV (release candidate, maintained)
#61
(12-10-2016, 11:15 AM)vially Wrote: I've just opened an issue on the issue tracker regarding mounting external USB drives
<snip>
PS: I'm using an USB 3.0 external hard drive plugged in an USB hub which is connected to an external power source.
Hi, you're probably more technical than I am, but I did see your 'PS' and noticed that info wasn't mentioned in the "steps to reproduce" in the issue tracker, so thought it might be worthwhile suggesting here (I know I've been caught with similar things in the past!). So have you tried:
a) plugging the drive directly into Pine64 without the USB hub?
b) a USB 2.0 drive?
I don't have a Pine assembled at the moment or I'd try these myself, especially since I'll need this feature too on ayufan's great Android 6 build, too. So please let us know how you get on!  Smile
#62
(12-12-2016, 05:03 AM)Crispin Wrote: Hi, you're probably more technical than I am, but I did see your 'PS' and noticed that info wasn't mentioned in the "steps to reproduce" in the issue tracker, so thought it might be worthwhile suggesting here (I know I've been caught with similar things in the past!). So have you tried:
b) a USB 2.0 drive?
Thanks for your help Crispin.
I've managed to get Android (and ES File Explorer) to recognize and mount the disk using a single FAT32 or NTFS partition using MBR partition table.
However now I'm having another issue: Kodi is unable to detect the USB drive so I can't play any files stored on this drive from Kodi.
I've also tried manually browsing from Kodi to /mnt/media_rw/0A67-1313 (where the disk partition gets mounted by Android) but Kodi seems unable to open the /mnt/media_rw directory (dmesg reports an access/permission denied error or something along those lines; I'm not at my PC right now and I can't check).
I'll try to investigate this further and I'll report here if I'll make any progress, but I'm very busy with work these days and I'm not sure if/when I can do that.
#63
Kodi is fixed: https://github.com/ayufan-pine64/device-...2337a64f27.
You can follow the progress here: https://jenkins.ayufan.eu/job/android-6.0-pine-a64/19/
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#64
Exist a way to update the system without format the micro SD?
#65
(12-12-2016, 03:55 PM)ayufan Wrote: Kodi is fixed: https://github.com/ayufan-pine64/device-...2337a64f27.
Awesome. Thanks for your work on this. I've tested it and it works now!
#66
good work for GbE lan working
#67
trenton4k: does it work for you?
Releases:
Buy me a Beer
#68
yea streaming 1080p video over lan work with no issue
#69
(12-03-2016, 04:03 AM)wernerhp Wrote: Anyone else not getting sound over HDMI?  Works fine over 3.5mm stereo jack and bluetooth.  2GB variant.
Having similar issues. I've had it work once with revision 19, but after a reboot, sound disappeared once again. Trying to figure out what I had done differently to make it work. The newest build (rev. 20) is running so smoothly, I really wanna try and use this as my daily driver. Any hints, ayufan?
#70
ayufan: Would it be possible to add a prameter (e.g. in uEnv.txt) for disabling CEC?
Thank you again for making this board useful with Android!
Shocked Remote for Android? liodra 18 29,737 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,850 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,997 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,068 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,623 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,344 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,888 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,554 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,381 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,684 01-07-2019, 01:21 AM
Users browsing this thread: 12 Guest(s)
