01-28-2016, 04:27 PM
Pink liquid cooling is an absolute must! Haha. But not something I'll be pursuing
Overclocking available?
01-29-2016, 06:38 AM
(01-28-2016, 03:55 PM)tllim Wrote:Thanks for the dimensions, now all i've got to do is wait until March(01-28-2016, 01:53 PM)frodo_loves_metal Wrote:The sandwich type acrylic case has around 20-22mm clearance (assume not install adapter on top), this should have enough clearance for ma good heatsink. The case height between two acrylic plate is 40mm.(01-28-2016, 01:20 PM)pine.tree Wrote: I measured the laptop fan, it is just under 20mm square. Does anyone know how tall the acrylic enclosure is? I might also put some fans on the side, totally out of the way of the board. I think there's a bit of room to all edges of the board, I could fit some fans in the outer perimeter of the case.
If I've helped you with something, please leave a rating for my responses.
02-06-2016, 08:52 PM
(01-28-2016, 12:44 PM)frodo_loves_metal Wrote:(01-28-2016, 07:28 AM)pine.tree Wrote:(01-28-2016, 07:11 AM)taros Wrote: The dimensions of the A64 (the SoC) are 15mm x 15mm. There is enough clearance for up to about 20mm x 20mm.
Backer number: 24,762
Backerkit STATUS: Items Received |
Overclocking | coleshores | 24 | 31,449 |
10-28-2016, 03:25 AM Last Post: pfeerick |
