08-25-2016, 08:12 AM
What is the password for the root user?
root password
08-25-2016, 08:30 AM
It depends on what image you are using. The best ones are on the pine64.pro page here: https://www.pine64.pro/downloads/ All of these list the default userid and password. If you are not using those builds then I am not entirely sure. I would try "debian" and "password"
08-25-2016, 08:49 AM
These two passwords have been tried out!!
08-25-2016, 09:44 AM
You haven't said which system are you using and what excatlyyou need it for. I think that there is no root password. You have to set it up yourself "sudo passwd root". If you want more help next time please provide more informations.
08-25-2016, 12:55 PM
Sorry, I was confused. The root password is a random thing. You can change it by logging in as the the "debian" user and using "sudo passwd" to change the root. In practice, I have found that is easier (and safer) to work as the debian user and runn sommands as root by running "sudo <command>". |
| root running from usb connected ssd locks up system | marcelser | 0 | 4,035 |
11-17-2017, 04:50 PM Last Post: marcelser |
| OMV base on Debian jessie Root Problem | ayamy | 3 | 8,364 |
09-03-2017, 09:21 PM Last Post: tllim |
| resize root partition to max available space SD card can provide | bilylilyli | 16 | 31,093 |
11-18-2016, 07:10 PM Last Post: pfeerick |
| how to use USB hard disk as /(root) | hatahata | 15 | 26,021 |
07-01-2016, 07:09 PM Last Post: hatahata |
How to resize the root partition in order to fully utilize the SD Card | MicroDiery | 5 | 11,174 |
05-24-2016, 05:48 AM Last Post: Luke |
| Debian root's password? | rayivy | 2 | 6,366 |
05-12-2016, 08:59 PM Last Post: rayivy |
| what is the root password for debian? | piahoo | 5 | 13,984 |
04-29-2016, 02:12 PM Last Post: rhkean |
