Vivaldi Web browser nearly native for Mobian
I have been using Libretranslate for a while as a webapp on my Pinephone Pro running Mobian Trixie, the free service seems to have been discontinued but I need translation as an everyday driver phone tool.
I found Vivaldi browser has an allegedly privacy oriented translation service included as a tool in the browser so I went to the website to see if it was compatible with the PP.  https://vivaldi.com/download/
The answer is yes they have an arm and arm64 version (deb and rpm) available for DL(mobian take the arm64 deb) which installs and runs on the PP, the UI is a bit smashed but everything has worked for me so far, as long as you are OK with using rotation a bit.
Is it really so private?  IDK there is this reddit discussion thread https://redlib.perennialte.ch/r/browsers..._security/
I have only done a small bit of testing the translation tool and tweaking of settings.  This Chromium based browser company is based in Europe, is supposedly a pro privacy employee owned company which only keeps back the add-on components from being all FOSS, built in translation, ad-blocker, other interesting vivaldi social media and messaging attempts, browser sync; it seems to work for the most part so you can also test out Vivaldi if you like.
https://en.wikipedia.org/wiki/Vivaldi_(web_browser)
FYI I went through and quickly disabled the main google attached search and call-home settings that I am familiar with, there may be more, but you can set dudkduckgo as a search engine and I think the ublock origin can be side loaded as well as the unofficial non-google chrome webstore app.
Exclamation
Reminder: Vivaldi is proprietary.
If you are going to use a proprietary translation service, you might as well just use Google Translate as a web app.
There is a free and apparently unrestricted instance of LibreTranslate running at https://translate.adminforge.de/.
(05-05-2025, 08:24 AM). Kevin Kofler Wrote: If you are going to use a proprietary translation service, you might as well just use Google Translate as a web app.
So thanks for the link, and goodbye to Vivaldi, though I think it is doing the translation locally, I will have to look.
I was thinking of setting up a libretranslate server on my VPS but there are problems with the OS version I am running that I can't change.
As far as less-bad I think MS translation has a better record after a privacy scandal vs Googl we know to be-evil which I have blacklisted for all purposes. If I really need google I have a VPN I use to access it..
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,362 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,649 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,690 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,126 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 271,878 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,902 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,432 06-07-2025, 03:19 PM
  mobian calamares fail merom 2 2,839 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,951 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 2,322 01-02-2025, 12:47 PM
Last Post: zetabeta
