What is the state of the PineTab2 today?
I am wondering about buying one for xmas lol. I'm seeing very mixed opinions on here many problems. Is it even worth it to buy?
If I recall correctly, the only thing not working out of the box, or with an update/restart, is the onboard bluetooth. I could be wrong though, as I haven't done the best at staying updated on its updates. You can check out the #pinetab chat room to find information on any updates, though.
Out of the box, I had to do some terminal work to get WiFi and BT setup and working; I also just enable them as needed. I don’t know the state of the current OS as shipped, as mine was a preorder & I’ve customized it quite a bit.
Once setup, I’ve found it to be a nice little device. The back-lit keyboard is fine to type on and it’s touchpad is accurate. The small form-factor/weight make it a perfect choice when I don’t need something more powerful.
I mainly use it for terminal, ebooks, office, music and light web work. LibreOffice, VLC, Calibre & Okular work fine. I’ve also got my BT JBL & Maxell devices functional.
Battery life is decent for what I’m using it for and on long days, I just add a powerbank. The build quality is fine; it’s held up well since I got it in 2023 and I’ve been using it most weekdays.
I never dealt with the camera or microphone and the speakers are okay for what they are.
Overall, I’m still satisfied with it.
Just keep in mind it’s limitations and if you want one soon, I’d order before the Chinese New Year holiday shutdown.
PinePhone, Pinebook Pro & PineTab2 owner.
  Pinetab2 not starting Corconegre 12 18,939 07-25-2025, 03:04 AM
  pinetab2 hardware is not very good lmartin 13 10,340 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,345 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 4,725 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 2,947 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,580 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,567 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 10,551 09-15-2023, 11:45 PM
Last Post: Ome Ko
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 6,126 09-06-2023, 07:43 PM
Last Post: bacon_dude
  PineTab2 screen won't turn back on until reboot KelsonV 3 3,698 08-23-2023, 09:08 AM
Last Post: diederik
