Pinetab 2 Not Powering On...
We recently purchased the tablet. It was working fine, but now isn't turning on at all...
Need technical support please... Undecided
(09-18-2024, 04:27 PM)FortranTraffic Wrote: Hi,
Try to use UART adapter and read the console message to determine cause.
I had the same problem with mine running the latest version of the default installation. If you left it without the power adapter plugged in for 5-10 days, let it charge with the appropriate rated charger for 72 hours or more.
I unplugged mine while I was gone on holiday and came back to what appeared to be a dead tablet, no response to anything (odd since I hadn’t used it, it was shut down and unplugged).
I tried the UART adapter- nothing, charged it for 24 hours- same, then took it apart, re-seated all the cables & still nothing. I put it all back together, left it on the charger for a few days and  then it was back to working as normal.
I never did figure out what drained the battery.
PinePhone, Pinebook Pro & PineTab2 owner.
(09-23-2024, 12:00 PM)dachalife Wrote: I had the same problem with mine running the latest version of the default installation. If you left it without the power adapter plugged in for 5-10 days, let it charge with the appropriate rated charger for 72 hours or more.
Thanks on sharing the experience, and already pass to product and support team.
On the upcoming PineTab-V, product team has added two LED indicator (charging and status).
  used PinePhone Mobian CE or PineTab CelynRollins 1 2,954 01-11-2022, 06:31 AM
Last Post: collierreinhold
  PineTab second batch guenther 2 2,933 10-28-2021, 08:42 AM
Last Post: guenther
  Looking to buy a used PinePhone Mobian CE or PineTab alontra 0 2,697 03-04-2021, 06:33 AM
Last Post: alontra
  Please create a PineTab section in the forum eaglecup 2 6,483 07-29-2020, 12:26 PM
Last Post: JamesGrelf
  fingerprint sensor on pinetab Goddard 1 4,217 06-10-2020, 09:43 AM
Last Post: Goddard
  PineTab beta/early adopter? ejbcomp 8 12,443 04-30-2020, 12:37 AM
Thumbs Up pinetab why is it called that? Goddard 5 9,198 03-15-2020, 11:01 AM
Last Post: Goddard
Question Is there a forum for PineTab? Danct12 3 8,725 01-31-2020, 08:23 PM
Last Post: InsideJob
Photo PinePhone and PineTab - Mobile Image Enhancement Techniques alexandercrypto 1 5,213 09-16-2019, 10:59 AM
  Pinetab secondary display? neverused 4 9,783 09-12-2019, 12:28 PM
Last Post: Kochise
