Im thinking of building a Pine64 cluster
So Im thinking of building a Pine64 cluster for a homelab over a Pi for a couple reasons, also being able to order more than one of the same type.
Their website sells USB to barrel power adapters awesome! But I need a power strip that can output 5V 3A for at least four USB ports.
I am not honestly that familiar with power usage and finding pieces but I see a lot of 2.4Amps with a max total of 12Amps. Out of a USB power strip. Is 3A really just 2.4?192.168.0.1 routerlogin 192.168.l.l
2.4A is already over the design spec for USB-A if my memory is correct.
If you need 4x3A, you may be better off "homebrewing" something with a 5V15A regulated supply, 4 3A fuses and 4 "barrel plug" cables. Otherwise just use 4 "barrel plug" wall warts. There's no real advantage in using USB for this, IMHO.
USB-C is different, and was actually designed with high current in mind. But I have no idea what's available for that, or if it even makes sense to use it, because a lot of USB-C power is delivered at higher than 5V. I'm pretty sure none of the Pine devices can take advantage of this.
:wq
  Has anyone installed Trisquel (linux-libre) on Pine64 RockPro64? libreboy 1 2,172 Yesterday, 12:08 PM
Last Post: RandB
  Problem joining Discord Pine64 dhdurgee 1 2,631 09-30-2025, 11:44 AM
Last Post: dhdurgee
  SBC Case Builder and Pine64 SBC hominoid 1 3,258 06-13-2025, 03:03 PM
Last Post: hominoid
Star Pine64 Logo Submissions Admiral Snackbar 0 1,985 06-08-2025, 03:00 PM
Last Post: Admiral Snackbar
  Anyone thinking about putting a RISC-V CPU in a watch? Darin755 1 2,430 03-18-2025, 05:55 PM
  Advice on Choosing the Best Pine64 Device for My Use Case? Ingrid 4 3,774 02-28-2025, 01:14 AM
Last Post: stefan_hdb
  Registering my 'nick' on Pine64's IRC network diederik 7 6,313 12-04-2024, 05:44 AM
Last Post: mmonster
  Star64/Starpro64 kernel building global 0 1,582 10-04-2024, 08:36 PM
Last Post: global
  Need Help Choosing the Right Pine64 Board for My Project jacoballen 1 2,277 09-22-2024, 06:28 PM
  [Article] RISC-V Emulator for Pine64 Oz64 SBC lupyuen 2 3,267 07-07-2024, 04:19 AM
Last Post: lupyuen
