Is it possible to use Pine-64 board as a Mini PC such as BeeLink?
Is it possible to use one of the Pine64 boards for use as a Arm Linux OS for use as a mini computer to use Ubuntu or Arch as a Linux desktop computer? And will Pine64 ever make a Linux Desktop mini pc version of hardware?
(08-30-2023, 02:19 PM)Omnios Wrote: Is it possible to use one of the Pine64 boards for use as a Arm Linux OS for use as a mini computer to use Ubuntu or Arch as a Linux desktop computer?
Yes, it is. Theoretically, it should be doable with any of the boards. (Heck, even the PinePhone could be used that way to some extent, though that is really not what it is for.) In practice, you will want to check the hardware specs. E.g., the Ox64 is completely minimalist without even a GPU or a video output, so not really suitable as a desktop replacement (even if you could theoretically get some slow video output from it with a USB 2 video card, though that alone will cost you more than the price difference to a less minimalist board), and it is also RISC-V rather than ARM. The STAR64 is more suitable, but also RISC-V and not ARM. The A64-LTS, ROCK64, ROCKPro64, and Quartz64 boards have an ARM CPU and a GPU, so they should be suitable. (The non-LTS A64 boards and the H64 boards appear to no longer be available, at least they are not in stock.)
Quote:And will Pine64 ever make a Linux Desktop mini pc version of hardware?
That, I cannot answer. I have no idea what products Pine64 is planning.
  Pine.org very poor review rma00 9 7,972 07-07-2025, 12:06 PM
Last Post: dachalife
  Replacement international plugs for 65W GaN Pine Power Cadair 1 2,368 05-20-2025, 10:20 PM
  Pine Desktop PowerSupply wont power on BSharp 6 5,860 01-07-2025, 08:04 AM
Last Post: skare
  What about a Pine digital audio player? ClairelyClaire 7 7,174 12-05-2024, 09:06 PM
  Need Help Choosing the Right Pine64 Board for My Project jacoballen 1 2,270 09-22-2024, 06:28 PM
  pine vacuum cleaner and door phone norayr 3 2,728 01-16-2024, 02:31 AM
Last Post: hanajijang
  Android OS that supports LCD touch panel (pine a64) Spekboy 0 1,534 01-14-2024, 01:41 PM
Last Post: Spekboy
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 1,989 09-21-2023, 07:52 AM
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 4,596 07-24-2023, 03:21 PM
Last Post: Omnios
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 2,997 03-10-2023, 03:35 PM
Last Post: peteressive
