Star64 booting up Armbian video
Here's my Star64 booting up Armbian for the first time on a 2GB microSD. https://youtu.be/3L0rNewF0QE
This Armbian image is based on Fishwaldo's kernel & device tree and this release of Armbian: Armbian_23.5.0-trunk.275_Star64_lunar_edge_5.15.0.img from here: https://www.armbian.com/star64/
I made an image of my 2GB drive in case anyone wants to write it to a microSD and try booting it. I'd recommend writing it to a larger microSD, maybe 16GB or more, because my 2GB quickly filled up. Armbian should automatically resize itself to fill your larger microSD.
You can find the compressed disk image on google drive: https://drive.google.com/file/d/1zIOl9xU...sp=sharing The shasum for the xz file is 4a1dc00d0ac27c690a04546c4447f6f96fe5f38f.
The green LED being on is normal. The blue activity LED (right next to the green one) should be blinking twice occasionally once it's out of the firmware and booting into Linux, otherwise there's an error causing it to be stuck in firmware.
The indications they're referring to is the position of the dip switches. You'll see a graphic to the left of them detailing the function each switch will have depending on the position each switch is in. The out-of-the-box positions of the switches (both switches in the "up" position) will allow for booting from the SD card (for me, anyway) so you shouldn't have worry about their location unless you have already flipped one or more of the switches.
  Zig booting up on PinePhone WhiteHexagon 0 1,859 07-19-2025, 03:11 AM
Last Post: WhiteHexagon
  Star64 distro overview October 2023 tantamount 7 6,549 01-11-2025, 09:12 AM
Last Post: gounthar
  star64 bootable images, u-boot, sbi, forum? hexdump 5 5,561 11-27-2024, 11:13 AM
  Star64/Starpro64 kernel building global 0 1,585 10-04-2024, 08:36 PM
Last Post: global
  [Video] TinyEMU RISC-V Emulator for Ox64 BL808 SBC lupyuen 0 1,587 06-13-2024, 08:56 PM
Last Post: lupyuen
  [Video] Adventures of Ox64 BL808 RISC-V SBC with Apache NuttX RTOS lupyuen 0 1,541 06-13-2024, 04:13 AM
Last Post: lupyuen
  Need help in understanding Yocto and U-boot build process for Star64 InterestedinFOSS 2 2,535 06-05-2024, 04:29 PM
Last Post: yogo1212
  [Star64] UART activity stopped yogo1212 0 1,503 02-11-2024, 04:34 PM
Last Post: yogo1212
  Star64 Mechanicals nbxmike 4 4,859 01-16-2024, 04:35 AM
Last Post: oilumiun12
  Armbian and AltLinux for Star64 (RISC-V) balbes150 28 20,840 11-24-2023, 06:26 AM
Last Post: balbes150
