Pine Desktop PowerSupply wont power on
Anyone else have a dead desktop 120W power supply?  It would occassionally flicker when I first got it, but seemed stable enough (dumb, I know).  Now its just kaput.
I dont know if anyone has had one die and got it back running again?  I love the little unit was great for my Pinebook and Pi/Arduinos.
Wondering if I just got a bad unit that I should have returned?  or worth fixing?
Thank!
I would advise against opening a power supply, as this can be dangerous. Probably best to open a ticket under https://support.pine64.org
(04-23-2023, 02:31 PM)fxc Wrote: I would advise against opening a power supply, as this can be dangerous. Probably best to open a ticket under https://support.pine64.org
Thats probably a good call. Smile  Do you know if failure rate in them is high? or low?
Here at the community we don't really have insight in that. From people often asking in the chat etc. I would say issues are more common than with other Pine devices but I know that the power supply has upgraded internals over the OEM design to increase the life span.
The 120W PinePower failure rate is quite low.
I've never had trouble like this myself, contact support
Tower Defense
Got the same problem, did you find a solution?
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 262 10-03-2025, 11:35 AM
Last Post: cowsay
  Pine.org very poor review rma00 9 8,009 07-07-2025, 12:06 PM
Last Post: dachalife
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 2,183 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 2,379 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 3,294 04-08-2025, 08:31 PM
Last Post: colajuices
  Help with high voltage power supply setup for electrospinning? namarang 3 3,861 12-11-2024, 09:47 PM
Last Post: NovaSpindle_X
  What about a Pine digital audio player? ClairelyClaire 7 7,196 12-05-2024, 09:06 PM
  Desktop ready? eiger3970 0 1,305 07-27-2024, 07:49 PM
Last Post: eiger3970
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 2,087 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 2,036 04-02-2024, 11:11 PM
Last Post: evilbunny
