Wifi doesn't work after update
Every time (during the last months) since kernel image 6.1 appeared when I try to update the system from Debian 11 to 12 (Mobian) I can't find wifi adapter and I have to go back to my backup version where everything works. How much time will it take additionally? What do I do wrong? Is there anyone having the same problem?
The firmware for the wifi card is now in non-free-firmware (it was in non-free before). Hence you need to append "non-free-firmware" to the lines reflecting bookworm in /etc/apt/sources.list
(04-14-2023, 06:28 AM)jsch Wrote: The firmware for the wifi card is now in non-free-firmware (it was in non-free before). Hence you need to append "non-free-firmware" to the lines reflecting bookworm in /etc/apt/sources.list
Thank you, it works now.
  Alarm clock doesn’t work Captain1ndustry 14 25,091 12-23-2025, 12:12 AM
  No touch KB after update(forky) biketool 4 747 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 1,005 10-22-2025, 07:14 AM
Last Post: anonymous
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 5,706 02-20-2025, 02:47 PM
Last Post: puffchumpy
  how to update mobian over tor vusra 14 16,636 12-04-2024, 07:01 PM
Last Post: vusra
  The program doesn`t detect the camera blag0rag 6 4,996 09-17-2024, 03:45 PM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 5,979 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 5,432 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 4,811 07-18-2023, 08:54 AM
Last Post: junelung
  PinePhone won't boot after software update jb2000 2 3,965 03-17-2023, 07:26 AM
