New out of box phone, vibrates and solid red light on charging
Just got new in box Pine Phone Pro, i pulled tape off battery.  reinserted, used usbC cable supplied and different chargers.
However, no matter what I try, the phone just vibrates endlessly and has a solid red light when connecting cable.
(03-24-2023, 11:32 AM)StuckInTheCloud Wrote: Just got new in box Pine Phone Pro, i pulled tape off battery.  reinserted, used usbC cable supplied and different chargers.
The battery probably discharged too much, so it can't continue to boot in that state. I would suggest to remove the cable and to power the device off, then hold the "volume up" button and reinsert the cable to make it boot into Tow-Boot's USB Mass Storage mode. The LED should turn blue while doing so. Let it charge there for multiple hours. If that didn't fix it you can also overwrite the eMMC from there.
  USB charging is unreliable lightwo 0 376 05-17-2024, 04:29 AM
Last Post: lightwo
  PinePhonePro turns on when connecting usb charging cable xt0 5 1,507 10-10-2023, 12:01 PM
Last Post: zetabeta
  Question on the keyboard battery with phone knoxvilles_joker 0 1,165 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 8,491 06-15-2022, 02:32 AM
Last Post: fxc
  Pine Store : Pine phone Pro Parts ? bcnaz 7 4,891 04-08-2022, 09:45 PM
Last Post: bcnaz
  Pine Phone Pro issues gmastap 0 1,293 03-14-2022, 07:21 AM
Last Post: gmastap
Question Battery not charging when run down to 0. iwm 2 2,082 02-08-2022, 10:45 AM
Last Post: mburns
  charging indicator nristen 16 10,484 02-03-2022, 04:36 PM
Last Post: phelion
  USB to PC connection not charging PPP tckosvic 0 987 02-01-2022, 05:40 PM
Last Post: tckosvic
