Pinecil v2 power cycles at higher voltages?
Question
Just got a v2, and love it. When I run it off of a 20w USB power supply at 9v (over USB-C) or 12v (with USB-C to DC), it runs fine. However, I have two USB power supplies that it can negotiate 20v with (with the DC cable, natch). One of them is a 100w, so it negotiates 20v/5a, and works fine. The other one is a 65w, so it negotiates 20v/3.25a, and once I hit the + to start it warming up, it blinks just for a second, power cycles, and dumps me back to the main menu.
Seeing as it runs fine negotiating 9v/2a on a 20w channel, and 20w/5a on a 100w channel, I'm not sure why it's choking on 20v/3.25a. This is on the latest stable IronOS firmware, v2.20, with no changes to default settings other than fast scrolling and blinking temp during cooldown. Any ideas?
(03-14-2023, 03:10 PM)clemon79 Wrote: Just got a v2, and love it. When I run it off of a 20w USB power supply at 9v (over USB-C) or 12v (with USB-C to DC), it runs fine. However, I have two USB power supplies that it can negotiate 20v with (with the DC cable, natch). One of them is a 100w, so it negotiates 20v/5a, and works fine. The other one is a 65w, so it negotiates 20v/3.25a, and once I hit the + to start it warming up, it blinks just for a second, power cycles, and dumps me back to the main menu.
Is your another unstable 20V PD charger Baseus brand name? If yes, try latest firmware in Pinecil. If doesnt help, use another PD charger.
I had similar issue, you can check my neighbored topic here.
(10-09-2023, 01:38 AM)Neitron4ik Wrote: Is your another unstable 20V PD charger Baseus brand name? If yes, try latest firmware in Pinecil.
It wasn't a Baseus, but many thanks, a firmware update fixed the issue, and it's working like a champ on 65w chargers now.
pinecil v2 with latest firmware and a ugreen nexode 140W. Goes up to 28.3 Volts and therefore heats up to max 420 degrees in 4 seconds!
  pinecil v2 reverse polarity issue adamsk1952 0 224 09-12-2024, 07:54 AM
Last Post: adamsk1952
Sad Pinecil V2 screw broken! Carol8 1 157 09-09-2024, 08:44 AM
Last Post: Carol8
  Pinecil on Amazon? WEF 5 1,452 09-05-2024, 08:23 AM
Last Post: Jeb
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 1 630 05-13-2024, 01:31 PM
  Connecting a power supply to the Pinecil jon_bondy 1 911 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 5,702 02-29-2024, 07:33 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 1,382 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 658 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 9,900 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 1,047 11-02-2023, 09:11 AM
Last Post: Harrysteed
