Unsuspend → Black screen
(06-14-2023, 01:32 AM)dante404 Wrote:
(05-09-2023, 07:50 AM)mdk Wrote: Noticed something else!
When the screen stays black the phone is hot.
It often happen while charging, maybe after hitting 100%.
Have to hard reboot.
Same here! Often in the morning (plugged in over night), it's dead...
Currently I THINK it doesn't happen (that often?) when my phone lays NOT completely on it's backside while charing over night but gets more 'ventilation'/fresh air (and so gets less hot)...
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Currently I THINK it doesn't happen (that often?) when my phone lays NOT completley on it's backside while charing over night but gets more 'ventilation'/fresh air (and so gets less hot)...
My phone barely even gets warm with the keyboard case acting as both a larger sink and I never lay it phone side down. The device itself just never wakes from sleep.
I think this mornings update MIGHT have fixed it, but need more time to confirm
Edit: nope
(06-16-2023, 07:08 AM)Melechtna Wrote: My phone barely even gets warm with the keyboard case acting as both a larger sink and I never lay it phone side down. The device itself just never wakes from sleep.
Interesting. Mine gets really warm/hot when charging, and is always warm when 'dead' in the morning I think...
You're probably using a charger that pumps out close to the devices limit. I had a similar issue when I initially tried to charge it with a Pixel brick that was at the highest recommended limit of the device. Switching to one with a lower amperage, I think 0.5 amps less, it didn't overheat near as bad, With the keyboard case however, I can plug this charger into the case, and the lower one into the phone, and it makes it charge "faster", without the overheating issue either.
Interesting, I will have to look into this and probably get an other charger... Thanks!
@topic: It seems that the position (or 'cooling') of the phone doesn't really matter, I think now I was wrong on this. (Or... that has changed because of summer... Wink )
To be clear, it IS against the user manual for the keyboard case to do this, the dual charging I mean, but the device crashes if it's too low on battery, so that's why I do this sometimes. My device is one that has the "battery won't charge" issue with the case, but I'm working on it.
  How to add an homemade app to the main screen? JChdeL 3 300 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 1,798 07-18-2025, 07:56 PM
  On-Screen Keyboard Arrow Keys biketool 10 5,346 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 7,547 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 1,765 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 1,827 06-24-2023, 01:55 PM
Last Post: freelectro
  Lock screen question: always squeekboard tuxcall 1 2,640 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 2,034 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 3,352 08-08-2022, 09:38 AM
Last Post: andrew907
