Has anyone successfully flashed an Ox64 (128Mb) from linux?
I'm following like 6 guides at once, I've tried bflb-mcu-tool, bouffalo-loader, etc., I have my ox64 wired up to a Raspberry Pi Pico and the machine itself appears as a serial port on my computer. But I can't figure out how to actually flash the 3-layer bin files that [1] lists. Every "official" piece of documentation says to use DevCube, but DevCube's linux binary is completely broken (it isn't marked as executable, and when you mark it as executable and try to run it, it craps out asking for some paleolithic version of glibc; the package released for my system's package manager is also named wrong, which is fun). I'm on day 3 of trying to get anything to write to this board and so far have made exactly 0 progress.
This thing is really making me miss by pinephone or rock64 where you just throw in an SD card with an image written to it and it just works.
[1] https://github.com/openbouffalo/buildroot_bouffalo
Hi there. I just flashed one of my Oxes to linux in my Ubuntu 20.04 LTS without much problem. Could ejectute last version of devcube without any fuss.
I understand your frustration. Just download the latest release from the git, I used the full version. Watch the video linked on the wiki page, and follow very carefully the instructions on the git page (the values from the video are obsolete, that of the git are correct).
I'm using an oldie usb to serial adapter, a FTDI one didn't work with DevCube (handsake error) but an even older PL23030 worked flawlessly. Might be because the FTDI has a DTR pin and the PL don't. Just be sure tx/rx pinout is correct.
(02-27-2023, 09:01 PM)slondr Wrote: I'm following like 6 guides at once, I've tried bflb-mcu-tool, bouffalo-loader, etc., I have my ox64 wired up to a Raspberry Pi Pico and the machine itself appears as a serial port on my computer. But I can't figure out how to actually flash the 3-layer bin files that [1] lists. Every "official" piece of documentation says to use DevCube, but DevCube's linux binary is completely broken (it isn't marked as executable, and when you mark it as executable and try to run it, it craps out asking for some paleolithic version of glibc; the package released for my system's package manager is also named wrong, which is fun). I'm on day 3 of trying to get anything to write to this board and so far have made exactly 0 progress.
Hello, did you ever solve this? I have the same issue trying to flash from ubuntu. Devcube does not launch( tried 1.8.3 and 1.8.9) , i tried on Mint also and it does get a bit further (launches but i cannot get the serial connection to work), even though the board is verified working with devcube on windows and i can flash it no problem with windows but would rather work in linux.
any advice would be a blessing.
You can try the method described here: https://pine64.org/documentation/Ox64/So...ing_method
  Has anyone installed Trisquel (linux-libre) on Pine64 RockPro64? libreboy 1 2,185 11-03-2025, 12:08 PM
Last Post: RandB
  [Article] RISC-V Ox64 BL808: UART Interrupt and Platform-Level Interrupt Controller lupyuen 3 9,476 11-03-2025, 12:54 AM
Last Post: smithjohns
  [article] Linux Phone Takeover Juergen 4 3,705 10-08-2025, 02:31 PM
Last Post: zech.dexos
  Is the Linux mobile phone still developing? CleanEnvironment 5 3,535 08-07-2024, 06:25 PM
  [Article] Rust Apps on Ox64 BL808 RISC-V SBC and Apache NuttX RTOS lupyuen 2 3,049 07-06-2024, 06:51 PM
Last Post: lupyuen
  [Video] TinyEMU RISC-V Emulator for Ox64 BL808 SBC lupyuen 0 1,596 06-13-2024, 08:56 PM
Last Post: lupyuen
  [Video] Adventures of Ox64 BL808 RISC-V SBC with Apache NuttX RTOS lupyuen 0 1,549 06-13-2024, 04:13 AM
Last Post: lupyuen
  [Ox64 BL808 SBC] Apache NuttX International Workshop: Jun 13 and 14 (Tokyo Time) lupyuen 0 1,480 06-11-2024, 12:52 AM
Last Post: lupyuen
  [Article] Coding Ox64 BL808 SBC the Drag-n-Drop Way lupyuen 3 3,182 04-02-2024, 07:38 AM
Last Post: Noahstorey
  xz package is severely affected with injected code in some linux distributions. zetabeta 0 1,492 03-29-2024, 02:57 PM
Last Post: zetabeta
