Is my pinephone pro worth resurrecting?
In the beginning of ppp sales, I was very active in trying to get phone going to make it usable (over 125 threads).  I worked diligently on the issues of memory, battery life, sms, mms, OS/desktop software etc. In the course of this my phone got borked due to sim/sd card holder wearing out due to excessive uses.  Wouldn't even make calls any more due to sim card not connecting.  Also, I never received the replacement card holder that I applied for and pinephone promised. I put phone away for 6 months into the "about to be discarded pile".
I noticed recently that there is available a replacement motherboard that says it has a new card holder.  I am seeking advice on whether to try the new MB or just permanently disengage from the pinephone pro effort.  My old plain pinephone at least makes calls and I use that occasionally and runs for a good while.
Assuming that, if I install a new motherboard, the phone will work, where is the system performance at now? Is this the same MB that was originally installed or have some changes been made?  If MB changes were made, what is best OS/desktop software anyone has had success with?
If no changes were made and phone is back to original, am I back to all the problems that people were banging their heads against before or is there now a workable combination of OS and desktop that works well enough so that phone is usable.  If so what are the suggestions as to "current best" software combination?
I was so hoping to get a linux phone working but I am nearly burned out on this effort.
tom kosvic
(02-27-2023, 09:33 AM)tckosvic Wrote: In the beginning of ppp sales, I was very active in trying to get phone going to make it usable (over 125 threads).  I worked diligently on the issues of memory, battery life, sms, mms, OS/desktop software etc. In the course of this my phone got borked due to sim/sd card holder wearing out due to excessive uses.  Wouldn't even make calls any more due to sim card not connecting.  Also, I never received the replacement card holder that I applied for and pinephone promised. I put phone away for 6 months into the "about to be discarded pile".
tom kosvic
Don't know.  I really like it though.  We seem to be losing support. for everything.
(02-27-2023, 11:13 AM)iwm Wrote: We seem to be losing support. for everything.
Oh... that sounds not good... Sad
You mean for PinePhone Pro?
Or PinePhone in general?
Support by Pine64?
Or by the oss community (perhaps because of the conflicts between community and Pine64)?
Or both...? Sad
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
All the support has moved to Telegram and Matrix. The community is vey much alive.
(02-27-2023, 09:33 AM)tckosvic Wrote: ...
tom kosvic
Question to anyone: is it possible to desolder and replace the existing SIM+microSD card socket from the mainboard without damaging the mainboard?
Theoretically it is possible, but maybe not in practice.
tom kosvic
The sim card slot can be repaired. I had a pin soldered on by a local repair shop. As I understand it , there are sim card slots from other manufacturers that will fit. Somewhere in these threads there are some suggestions as to which ones will fit.
tom kosvic
Did you ever get the device repaired?
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 9,090 03-13-2025, 08:40 PM
Last Post: pcb
  New PinePhone Pro. No sudo command or access to root password. DanNewman 4 1,177 03-01-2025, 06:38 PM
  PinePhone Pro Review tmoj 4 5,891 02-20-2025, 12:45 AM
  Feedback from unboxing a new PinePhone Pro (cc: Pine64) teekay 0 627 02-08-2025, 01:37 AM
Last Post: teekay
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 6 3,585 12-23-2024, 02:42 PM
  PinePhone Pro Black Screen CrimsenRaven 3 2,481 11-13-2024, 09:33 PM
Last Post: twentyslimy
  PinePhone Pro/IMX258 Camera Debugging problem jasperji 2 1,744 10-20-2024, 03:59 AM
Last Post: Jite
  Having difficulty installing PostmarketOS on Pinephone Convergence Beta edition spazz 13 3,432 10-17-2024, 03:28 PM
Last Post: fhilliard41
  PinePhone doesn't boot anymore lapin 3 1,493 09-13-2024, 10:09 AM
Last Post: lapin
  New PinePhone Pro fails... P. Siera 5 2,558 08-01-2024, 04:56 AM
Last Post: P. Siera
