SFOS 4.4.0.72, with calls
The sailfishos port for pinephone, pinetab and pinephonepro is now updated to the latest sfos release 4.4.0.72. Current state: calls now work and wake device from deep sleep, but call audio is poor at the moment....everything else works except the following:
Not working - camera (waiting for development of libcamera);
Wifi disconnects after sleep, it needs to be toggled off and back on. The indicator shows it as still connected but if you check under Settings>Developer Tools you can see the WLAN IP address field is empty.
There is a new wiki for documentation: https://github.com/sailfish-on-dontbeevi...ation/wiki
The flash-it script works for emmc and sdcards. The option "raw" to write an image on your pc is still broken.
Waydroid works but is very sluggish and a battery guzzler. In theory it needs 6GB ram so especially on original PP it's always going to be slow.
Update edit: after a period of about 3hrs the screen now longer wakes and the only option is to force shutdown (power button for 5 seconds) and reboot.
Initially posted here as this topic was not opened yet.
In addition to that:
1. After some time of inactivity mobile connection gets dropped and no way to recover when locked SIM
2. Was unable to mount my usbA/usbC combo stick (this worked in earlier versions as I used that for backup/restore)
3. Recreating sd card with flash-it gets mobile connection back as sim unlocking works during first-run-wizard. (Some racing condition during later reboots?) Voice quality during calling was not too bad Smile
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
(12-25-2022, 03:01 PM)acrux Wrote: Initially posted here as this topic was not opened yet.
I’ve tried this for a week, and I’ve got to say I’m pretty impressed.
Not quite perfect yet, but certainly good enough to get by.
Hope the updates keep comingSmile
Ok so I'm having a little trouble using the flash-it.sh script to install the Sailfish OS to my SD Card ?
I've followed the instructions @ https://github.com/sailfish-on-dontbeevi...stallation
and https://github.com/sailfish-on-dontbeevi...ation/wiki
(Correctly I think)
I'm able to run flash-it.sh and I can select the No. 5 option for my new Pine Phone Pro however I just keep getting the error ;
UBoot image download failed. Aborting.
Not sure if I'm missing something bleeding obvious. Is it a problem with the script currently or am I doing something wrong ?
Any assistance is gratefully appreciated in advance
Smile
This is a known issue Smile
Here in PINE64 › PinePhone › PinePhone Software › SailfishOS on PinePhone is another topic: Script not working
https://forum.pine64.org/showthread.php?tid=17694
I was able to fix the script using info provided there.
As you have a PinePhonePro, then I guess you have to use corresponding image instead of *book* image.
(04-16-2023, 08:51 AM)acrux Wrote: This is a known issue Smile
Thanks for the help and response acrux will take a look and will see how I go
I'm "stumbling" around a little here will post on the Sailfish forum and see if I can get a little guidance on which is and where to get the correct Pine Phone Pro Sailfish image ?
Ta Smile
  SFOS 4.5.0.19 improved call audio and camera defactofactotum 1 1,531 08-31-2023, 03:29 PM
  SFOS 4.3 wryun 4 3,588 03-25-2022, 03:24 PM
Last Post: Maus
  SFOS 4.2 defactofactotum 10 8,581 10-04-2021, 03:26 AM
Last Post: acrux
  SFOS 4.1.0.24 aarch64 defactofactotum 5 5,460 08-13-2021, 12:13 AM
Last Post: acrux
  SFOS 4.0.1.48 defactofactotum 8 8,885 06-01-2021, 01:42 PM
Last Post: OhneZ
  Img now updated to sfos 3.4.0.24 defactofactotum 8 9,553 11-08-2020, 12:53 PM
Last Post: clover
