problem with boot
when I record any operating system, pinephone does not turn on, neither the led nor the screen lights up.
(11-22-2022, 01:49 PM)evaldas Wrote: when I record any operating system, pinephone does not turn on, neither the led nor the screen lights up.
That can have multiple causes, e. g. a drained battery or a corrupted installation. The LED and the screen backlight isn't used early in the boot process, which means if the installation got corrupted you won't see any error message or LED activity.
Best if you put Jumpdrive on a microSD card and try to boot that. You can download Jumpdrive from https://github.com/dreemurrs-embedded/Ju...one.img.xz. Please let us know if there is any question or issue and if that worked.
  Can't boot on SD anymore LeNouveau 1 3,646 02-12-2024, 01:05 PM
Last Post: LeNouveau
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 1,910 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  Tow-boot headaches. antiwesley 3 3,491 04-30-2023, 05:03 PM
  Article: NuttX RTOS for PinePhone: Boot to LVGL lupyuen 2 3,533 01-23-2023, 10:41 PM
Last Post: lupyuen
  tow-boot shulamy 2 3,183 09-08-2022, 12:33 AM
Last Post: shulamy
  Device memory full on multi-boot SD card Peter Gamma 4 5,156 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 5,907 08-17-2022, 03:38 AM
Last Post: shulamy
  Change tow-boot boot order or otherwise make Mobian on uSD the default? allworlds 3 4,329 05-04-2022, 06:27 PM
Last Post: allworlds
  Problem Flashing the modem Firmware loreson 0 2,032 12-22-2021, 10:31 AM
Last Post: loreson
  Multi boot issue generaluser 4 5,361 10-06-2021, 07:45 AM
Last Post: generaluser
