Where to Get Sufficient Suppor for Pinephone Pro?
If I cannot get any support or sufficient support in this forum, where can I get some regarding Pinephone Pro Audio ?
The audio and phone calls issue is plaguing many users, including my self.  Rendering the phone useless, to be tested as a "daily driver".
I had been battling this audio calls issue for a month, to get Pinephone Pro to behave like a "phone", and no avail.
Is there a sub-forum that deals with this major blow-back against the hardware I am trying to adapt, and others too?  Is there a unified section that gives some better idea if the issue is related to Pulseaudio, Wirepipe, modem settings.. etc...
I do not think I am the only one who is dealing with this, and not much I can find as a solution.
I have been trying many steps that I find scattered in this forum. and throughout the internet, and non works.
Do I have to be part of a club to get the insider solutions ? Not all of us into Telegram, Matrix and so forth.. it would be better if in egalitarian fashion that knowledge is spread and preserved for ALL to utilize and contribute to.
We do learn from the learned, when they give us attention, and so forth, things begin to flow...
Would it be possible to create a Sticky or a sub-forum to deal with this major issue with Pinephone Pro adaptation as a "phone" and perhaps, for a better run as being a "daily driver" , when the AUDIO CALLS are existing?
Thanx
Could we rename this thread something like "PPP audio discussion and support"?
I thought I saw the other day a post about someone who was using mobian with a specific kernel that enabled audio to work better after waking from suspend.  I am not finding that post right now.  I will keep looking.
For what it's worth I got a pine phone pro delivered this past week and have had the following experience with respect to audio and calling:
The stock OS has no sound in calls.  Perhaps I did not set it up correctly.
I tried the Manjaro-Phosh image from 11/10.  Sound on calls did not work.  Perhaps I did not set it up correctly.
I tried the recent mobian (11/06 image).  Sound on calls worked once, then did not.  But since doing an
  # apt-get update && apt-get upgrade
sound has worked, though with poor quality going out from the pine phone, on calls for the couple of trials I have done over the last day, including incoming calls from suspend.
I recently received my ppp and had a lot of the same issues. Ultimately I found postmarketos posh or plasma makes calls pretty consistently. It sometimes drops calls and requires a reboot to make calls again. But overall it works.
(11-05-2022, 10:37 PM)X0X0X0X0X0 Wrote: If I cannot get any support or sufficient support in this forum, where can I get some regarding Pinephone Pro Audio ?
Thanx
To answer the question if there are insider solutions or hidden places, there are not. The community channel is bridged so you can join it with your favorite client from either IRC, Telegram, Matrix or Discord, so there are wide possibilities to reach out to the community.
Because you are writing "when they give us attention" please keep in mind that there is no "we" and "them", the software is written by the community. The reason you do find bugs and (outdated) solutions spread across multiple places is because the batch you bought is intended for (kernel) developers only as per warning on the store, so there is a bit of expectation that you contribute to the low-level functionality (including audio). Please feel free to contribute by collection the information, update them, update documentation, report and investigate into bugs or by development contributions!
Information regarding the bridged community channel can be found in the following page: https://wiki.pine64.org/wiki/Main_Page#Chat_Platforms
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 10 1,700 2 hours ago
Last Post: mburns
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,038 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 826 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 960 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 699 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,711 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,358 09-10-2023, 03:19 AM
Last Post: fxc
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,451 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Cannot update new PinePhone Pro bent 6 3,487 05-15-2023, 02:43 PM
Last Post: alaraajavamma
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,521 05-12-2023, 12:58 PM
