Pinephone lost graphic during mobian system upgrade
Wink
I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
(10-18-2022, 12:55 AM)cmpin Wrote: I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
Do you get the decypt password question before black screen?
Is it the same problem than mine?
https://forum.pine64.org/showthread.php?tid=17899
(02-28-2023, 12:40 PM)anonymous Wrote: Is it the same problem than mine?
Mine new install does the same as yours. I had to reinstall last year due to upgrade stopping the system even booting. Just got red led flash and haptic for 5sec and then it turned off.
Have you tried to reinstall, disable greetd and re-enable phosh before upgrading like I did?
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,631 Yesterday, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,011 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 162 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,724 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,098 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Errors when start the system kubussz 2 626 11-21-2023, 11:07 AM
Last Post: kubussz
  System won't suspend due to suspention notification user641 6 1,532 09-24-2023, 05:47 AM
Last Post: user641
  What actions needed to keep on mobian testing user641 3 1,896 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 660 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,102 07-09-2023, 08:57 PM
Last Post: vusra
