No sound
#21
(10-28-2022, 05:13 AM)dante404 Wrote: Then I will wait with switching to pipewire - Thanks for posting!!!
Interesting: The last 2 or 3 reboots pulse audio startet automatically as it should do and has done before! There was no pulseaudio update the last days, perhaps any other update somehow 'fixed' this... or it's just random/luck.  Huh I will further observe this when rebooting the next days.
Bookworm is in a transition from pulseaudio to pipewire so that's the likely cause of some recent audio breakage.  I did a dist-upgrade today - the first since late September - and got many pipewire-related packages but lost things like audible call & sms notifications.  The only thing I had to do to get sound back was
systemctl --user --now disable pulseaudio.service pulseaudio.socket
Stuff just worked after that (so far), even after reboot.
p, li { white-space: pre-wrap; }
A few days ago I upgraded my modem firmware from 01.001.01.001 to 30.006.30.006 and haven't had any issues with sound stopping and needing to restart pipewire since. Possibly coincidence.
(Unfortunately the firmware update didn't help improve call/text reliability or overall system stability like I was hoping, but the sound has been fine...)
(11-04-2022, 02:06 PM)treebeard Wrote: Bookworm is in a transition from pulseaudio to pipewire so that's the likely cause of some recent audio breakage.  I did a dist-upgrade today - the first since late September - and got many pipewire-related packages but lost things like audible call & sms notifications.  The only thing I had to do to get sound back was
Thanks for the info!!
But I think I'm staying with pulseaudio for now (and manually start it after reboot, necessary 4/5 times I would say - At least this works 100% then), I suddenly have so many problems right now (modem also) with my Mobian phone (which appeared through regular updates (or the hardware get faulty??)), I'm currently afraid of any 'experiments'... Sad
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
  Sound : notifications freelectro 6 5,842 06-07-2023, 01:03 AM
Last Post: freelectro
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 5,029 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 2,018 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 5,459 12-27-2021, 05:40 AM
Last Post: Anna
Bug Sound defaults to Headset User 18618 10 13,999 10-21-2020, 06:06 PM
Last Post: ThrillGates
  No Sound After Reboots LMalilil 1 3,774 09-23-2020, 06:14 AM
Last Post: bobblestiltskin
  earpiece sound setting Gobelin 3 5,012 08-13-2020, 01:46 PM
Last Post: Gobelin
