Use pinecil (V1) as a high temp thermoemter?
Long story short: Need to do a reflowing of my PS3, don't have the money to pay someone to do a reballing and dont have the tools for it, checking a guide to do reflowing on a normal oven made me want to attempt this, rn all I need is a somewhat accurate oven thermometer but all the ones i checked that are under 20€ are useless for what i can see on the reviews.
The pinecil can read over 400ºC no problem, i wouldnt need more range than 100 to 300ºC, so, anyway i could hook up a thermocouple or something to the pinecil and check the temp in real time? As long as it's kind of accurate (+/-10ºC) it's all i need.
I know it uses a handle sensor and a tip sensor to calculate temp but if i can have the ambient temp kinda controlled for a short amount of time could it read accurately? if so what i'd need to do in order to achieve this? Any help is welcome!
(10-06-2022, 07:26 PM)Ko1 Wrote: Long story short: Need to do a reflowing of my PS3, don't have the money to pay someone to do a reballing and dont have the tools for it, checking a guide to do reflowing on a normal oven made me want to attempt this, rn all I need is a somewhat accurate oven thermometer but all the ones i checked that are under 20€ are useless for what i can see on the reviews.
I don't recommend you to use your normal oven for reflowing if you still want to cook in it later.
There are a lot of potential harmful materials coming out during this process what you don't want to eat later...
Don't use anything that is used for cooking. but there are videos on YT showing use of a Thin layer of fine sand and a used frying pan that is not used for anything else (see GreatScott) . the fine sand helps even the temps.
There is also a Live volunteer active channel is in discord but has bridge to other comms too. many of the most active volunteers don't check these forums, it is a fluke I happen to be in here today looking for something else.
Links to join live Pine64/pincil chat is in Pinecil Wiki Pages. https://wiki.pine64.org/wiki/Pinecil#Community_links
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 403 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 744 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,065 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,689 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,435 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,119 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 0 1,674 03-22-2025, 07:29 AM
Last Post: BigCarrotLeaf
  Pinecil constantly cutting out WroughtIron 1 2,504 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 1,767 01-07-2025, 03:59 PM
Last Post: MizterPink
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 1,357 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
