Does the pinephone have hardware kill switches located on the outside of the phone?
From what I have seen (at least in the past), pinphones have hardware kill switches on the inside of the phone, it is located behind the battery or something.
Does the current version of the pinephone have hardware kill switches on the outside of the phone, like for example on the side of the phone, like the way how librem phones do?
https://puri.sm/products/librem-5/
or is this something planned in the next version of the pinephone?
It makes sense to put it on the side of the phone rather than on the inside as it allows the user to disable microphone, camera etc whenever they are not in use rather than having to open the back of the phone just to do this. For example if I am getting a call I would have to open the back just to turn the microphone on before answering the call, on the librem phone I can just flick the switch and then talk to the person.
(10-02-2022, 10:15 PM)unix21311 Wrote: From what I have seen (at least in the past), pinphones have hardware kill switches on the inside of the phone, it is located behind the battery or something.
switches are not behind battery, but there are behind back cover. these pictures show it enough https://barrelmem.s3.eu-north-1.amazonaw...index.html .
i canont speak for the pine organization. i don't think we see switches outside the phone. someone proposed a hole for back cover, but even in this case, switches are small and inconvenient. i used sim removal tool to switch those switches.
going on speculative rant, would physically bigger pinephone be a good idea! maybe yes, then there is more room for outside switches and for bigger battery.
> But even in this case, switches are small and inconvenient.
But I don't think its that bad if you looked at the librem 5. I think its even more inconvenient to have it behind the back cover then to have hte switches on the back side.
  is cpu rk3576 suited for use in a phone? heocb 1 693 01-28-2026, 12:45 PM
  [article] Linux Phone Takeover Juergen 4 5,025 10-08-2025, 02:31 PM
Last Post: zech.dexos
  Zig booting up on PinePhone WhiteHexagon 0 2,629 07-19-2025, 03:11 AM
Last Post: WhiteHexagon
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 3,070 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  [Article] Test Bot for NuttX Pull Requests ... Tested on Real Hardware (Oz64 SG2000) lupyuen 0 2,794 02-15-2025, 11:26 AM
Last Post: lupyuen
  Second-Hand PinePhone rdv 9 5,821 01-05-2025, 11:42 PM
  pinephone 3 ideas aular 5 5,296 11-08-2024, 06:35 AM
  Is the Linux mobile phone still developing? CleanEnvironment 5 4,213 08-07-2024, 06:25 PM
  Enhancing Privacy with additional hardware killswitches Substing 2 3,044 07-25-2024, 07:49 PM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 3,090 04-11-2024, 03:10 PM
