keyboard charging fault, chip "most likely damaged", how to be sure?
The battery component of my pinephone keyboard is malfunctioning with symptoms described exactly in megi's FAQ, so I'm just quoting them here (emphasis mine):
Quote:Phone is not charging from the keyboard battery at all and keyboard power button does nothing
If
/sys/class/power_supply/ip5xxx-battery/uevent
does not become available, even when connecting the USB power supply to the keyboard, and is empty, that means that the charger chip is not responding, even when powered up. That means the chip is most likely damaged.
(source: https://xnux.eu/pinephone-keyboard/faq.html)
"most likely damaged", it says. Is there a known alternative possibility that I could test for, and possible ways to fix the unit?
I have had the keyboard for only a month and have barely used it. I was very aware that I should never charge it through the phone's USB-C socket and I am pretty sure I didn't. I did leave it connected to a charger via the keyboard's socket for a week once and maybe that's when the fault happened, although that still seems surprising to me.
I got it working again. The trick was to press the keyboard's power button *while* it was connected to a power supply.
  keyboard case charging but not typing new2pinephone 18 5,768 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,491 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 424 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,167 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,232 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 514 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 615 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 828 10-11-2023, 09:03 AM
Last Post: elof
