[Fixed] Phosh crashes frequently after latest updates
The issue seems to be related to https://gitlab.gnome.org/World/Phosh/phosh/-/issues/840 and https://gitlab.gnome.org/World/Phosh/phosh/-/issues/841
glib 2.74 does no longer support G_REGEX_JAVASCRIPT_COMPAT whereas phosh was build with using that regex type/module
So we have to wait for a newer phosh release (or one compiled with a different flag?) before it's safe to upgrade libglib2
(09-22-2022, 11:20 AM)jsch Wrote: The issue seems to be related to https://gitlab.gnome.org/World/Phosh/phosh/-/issues/840 and https://gitlab.gnome.org/World/Phosh/phosh/-/issues/841
Downgrading the three liglib2 packages did the trick - thanks a million!
And to keep these packages even after the next update, it is neccessary to mark the packages on hold like this
sudo apt-mark hold libglib2.0-0 libglib2.0-bin libglib2.0-data
Type unhold for updating, when the issue with Phosh is solved.
Cheers!
(09-22-2022, 12:55 PM)arno_nuehm Wrote: Downgrading the three liglib2 packages did the trick - thanks a million!
I would like to know how to do that please.
Thank you very much!
jsch posted the solution:
wget http://snapshot.debian.org/archive/debian/20220831T091202Z/pool/main/g/glib2.0/libglib2.0-bin_2.73.3-3_arm64.deb http://snapshot.debian.org/archive/debian/20220831T091202Z/pool/main/g/glib2.0/libglib2.0-data_2.73.3-3_all.deb http://snapshot.debian.org/archive/debian/20220831T091202Z/pool/main/g/glib2.0/libglib2.0-0_2.73.3-3_arm64.deb
sudo dpkg -i libglib2.0-0_2.73.3-3_arm64.deb libglib2.0-bin_2.73.3-3_arm64.deb libglib2.0-data_2.73.3-3_all.deb
If you want to get updates run again, you have to downgrade three other packages:
wget https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/libgirepository-1.0-1_1.73.0%2Bds-1_arm64.deb https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/gir1.2-glib-2.0_1.73.0%2Bds-1_arm64.deb https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/gir1.2-freedesktop_1.73.0%2Bds-1_arm64.deb
sudo dpkg -i libgirepository-1.0-1_1.73.0+ds-1_arm64.deb gir1.2-glib-2.0_1.73.0+ds-1_arm64.deb gir1.2-freedesktop_1.73.0%2Bds-1_arm64.deb
sudo apt-mark hold libgirepository-1.0-1 gir1.2-glib-2.0 gir1.2-freedesktop
After this, updates should work again...
Thumbs Up
Thank you jsch !
Thank you arno_nuehm !
You have saved the day! Smile
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
It works anew. I updated and upgraded about 3 hours ago, I have no longer any crash.
I ran updates today after about a week and all seems to be OK as well. I did a full image backup first just in case, then ran update, upgrade, and dist-upgrade. I checked to see if dist-upgrade was going to clobber anything like when it removed the "Settings" program a little while ago and nothing looked dangerous. Rebooted and as far as I can tell nothing is amiss. Phosh is stable, nothing seems to be missing, address book looks OK, and the phone can make calls.
Confirmed, after I did:
sudo apt-mark unhold libglib2.0-0 libglib2.0-bin libglib2.0-data
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
...and rebooted, everythings back to normal! Smile
Can confirm, too.
Had to unhold the three other libg2 packages.
Marking as solved.
  Auto start application on Phosh login Zebulon Walton 8 3,565 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  No volume control after latest updates Zebulon Walton 19 7,431 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,751 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 1,323 06-24-2023, 04:29 PM
  Using sway along phosh fdlamotte 2 3,378 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 4,481 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,869 02-24-2023, 12:11 AM
Last Post: nexion
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,525 11-28-2022, 03:30 PM
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,780 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,529 09-21-2022, 02:39 PM
