Enable 'upcoming-events' on Mobian/Phosh
Hey folks,
Is anybody familiar with how to enable the Calendar/Upcoming Events plugins in Phosh via gsettings? (Highlighted in: https://gitlab.gnome.org/World/Phosh/pho...gs/v0.21.0)
The switch to enable is supposed to be in phosh-mobile-settings (https://gitlab.gnome.org/guidog/phosh-mobile-settings) as of v0.21.0 but under Widgets, there are no buttons and only 'Additional widgets for the lock screen. This feature is experimental.' is displayed. I'm thinking enabling via gsettings might just be easier at this point.
I'm running Phosh 0.21.0 and Phoc 0.21.1 on Mobian.
Thanks!
Good spot :-)
Can´t see anything different to you on my arch install to enable it though.
(09-03-2022, 08:21 PM)Korac Wrote: Hey folks,
Thanks!
You need to install phosh-plugins in mobian. just via apt like usual. then two plugins should appear in the settings application afterwards.
Then swipe from left to right to open the events on the lock screen.
(09-08-2022, 07:32 AM)duh Wrote: ...
Now working in arch as well with latest phosh/phoc. Took me a while to realise I had to swipe right though!
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 1,974 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 19,706 03-31-2023, 04:17 AM
Last Post: Eugo
  Fedora + Phosh for PinePhone njha 74 177,258 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 5,811 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 3,887 08-15-2022, 06:39 AM
Last Post: nemsys
  Change tow-boot boot order or otherwise make Mobian on uSD the default? allworlds 3 3,836 05-04-2022, 06:27 PM
Last Post: allworlds
  Building an image with phosh liara 1 2,828 02-01-2022, 08:26 AM
Last Post: kqlnut
  More useful terminal key layout for phosh's squeekboard Boern 21 36,152 01-15-2022, 02:35 PM
Last Post: gilwood
  Phosh: Idles to Lockscreen Without Powering Off Display Merc 1 2,809 11-01-2021, 09:00 AM
Last Post: e1337
  Phosh - config within Settings does not save after reboot antitheos 0 2,055 09-24-2021, 04:30 PM
Last Post: antitheos
