quartz64 model b 2x20 pin header
can you provide the manufacturer and model number for the 2x20 pin header that is soldered onto the quartz64 model b?
I don't know the precise model number, but it's generic 2.54mm spacing, so there's a lot of manufacturers to choose mating connectors from.
If you want a mating connector that stacks (i.e. the pins are long enough to poke out the other side of the PCB), then SSQ-120-03-G-D should fit, but I'm sure there's cheaper options. For example this one looks good for $1, though isn't gold plated.
That's all of course assuming you're trying to build a board that plugs into the Quartz64 Model B and were trying to find mating connectors. If not, I apologise for the needless noise. Smile
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  The "Should I buy a Quartz64 right now?" flow chart CounterPillow 4 6,663 03-06-2025, 08:35 PM
Last Post: corruptgnu
  Quartz64 seeming died Darin755 0 830 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 2,541 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 1,926 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 2,075 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 10,541 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 13,127 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 13,077 01-23-2023, 03:31 AM
Last Post: balbes150
  quartz64 model b 2x20 max power proj964 1 2,509 10-23-2022, 05:32 AM
Last Post: CounterPillow
  JTAG/SWD on Quartz64 model A capablegh 4 7,077 10-03-2022, 03:16 PM
Last Post: fatalfeel
