Pinetime Screen issue after bootloop troubles
(09-15-2022, 05:40 AM)wibble Wrote: The heart rate sensor window is clear plastic, stuck to the back cover. Depending on how well I align it when I put the back cover on it sometimes looks like there's some pressure on the back, raising the middle of the window slightly. It's seem most easily if you view at an angle to see the distortion of the reflection on the window. I could imagine this leading to a leak over time. Since I stuck the back on myself I've assumed it will leak, but between sweat and rain it's been ok so far.
I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
The erosion definitely looks as if it came through the area where there is the heart rate window. The rest of the PCB looks corrosion free.
It still may not explain the display though.
@Spater How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
Thanks @wibble for looking into the assembly of the heart rate sensor and case fitting.
Quote:I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
@barray you are right, I have the Sealed version of Pinetime.
Quote:How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
I used pure Isopropyl alcohol to clean it.
Quote:It still may not explain the display though.
Took a look at the back of screen, could the spot in the red circle (see attached picture) be due to some kind of overheating?
Looks like there's something on the back of the board in the same location, but it's out of focus. What is it?
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,209 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,927 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,917 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,364 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,307 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,492 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,892 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,876 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,733 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,734 01-31-2024, 11:57 AM
Last Post: tynstar
